Hi all.
Does anyone know to enable dragondos *AND* specify a tape file to load, if I use
Xroar on it's own I get dragon32/dragondos combo which I believe is the default.
if I specify xroar -load file.cas it starts up without dos enabled.
There is a -nodos option to disable dos, but doesn't seem to be one that will force dos to be enabled even when loading a tape.
What would be even cooler would be to be able to specify a tape and a disk image and have the contents of the tape image transfered to disk.....
Xroar howto....
Re: Xroar howto....
Well...
The command line options seem mutually exclusive, but you can launch XRoar with your favourite DOS rom, and then use CTRL+L twice, one to load the tape, and one to other the disk. That way you can transfer tape contents to disk (that's what I usually do).
Maybe it would be good to have the some command line options like "-tape filename", "-disk1 filename", besides "-cart", only to have the media inserted in place.
Re: Xroar howto....
Sounds like something that needs consideration, yes.
The current behaviour is usually the "Right Thing", but I didn't notice there was no way to override it.
Re: Xroar howto....
As for the Load command line options, its absolutely correct, but it would be nice to have have "Media Insert" command line options.
I know, we are always asking for new features...
