GTK Libs for XRoar-GTK-w32
For those MS Windows users who do not want to download the latest GTK+ all-in-one bundle from http://www.gtk.org/download/win32.php and then work out through trial and error which DLLs XRoar GTK+ needs I attach a file that contains the required DLLs and nothing else. Just unzip the DLLs, plus the DLLs from the corresponding non-GTK+ version of XRoar, into the same directory as the xroar-gtk-w32.exe executable. (This file supersedes that found at viewtopic.php?p=2567#p2567.)
gtk_2.24.10-20120208_libs_for_xroar-windows32.zip
(4.75 MiB) Downloaded 551 times
P.S. Happy New Year everyone!
Re: GTK Libs for XRoar-GTK-w32
Cool, thanks for this Alastair!
That's still an awful lot of library just to get some menus, eh?
If a lot of people are actually using the GTK+ version, I'll start putting up builds of it along with the rest. Maybe until I get around to learning FLTK, which looks like it should do the same thing in less library.
Alastair wrote: P.S. Happy New Year everyone!
Happy New Year! :D
Aye, happy 2013 :)
Hello Ciaran,
I forgot at that time to test the GTK+ menus.
Now I have had the chance to give it a try and it is really very interesting for me, it gives a lot more control (disks and tapes) not to mention the ease to change machine configuration without having to close and launch another bat file!!
Unfortunately the last xroar-gtk I have access to is version 0.31, not the 0.31.1 or the latest snapshot.
Is there any chance for you to add this version whith every update? I would really appreciate it.
I understand that this can ONLY work with the windows32 version, could it work in w64 version?
thanks beforehand
It does work on 64-bit windows OS too.
I use the gtk version on my win7 64-bit without any problem.
hello,
thanks for your answer, I assume that you are compiling the source to get a w64 + GTK executable, because I have never seen a w64 version from Ciaran (just w32)
What would I need to compile the 64 version?
Is the GTK+ version as good as using batch files? Can you select between 100's of different configurations using custom ROMs and hardware settings?
I think that it's not thought for that, you could work out some configurations ...
I attach the five submenus that appear with win32 version 0.31
Tool Menu
Tool Menu
Cartridge Menu
Cartridge Menu
Machine Menu
Machine Menu
View Menu
View Menu
FILE Menu
FILE Menu
pser1 wrote:I think that it's not thought for that, you could work out some configurations ...
Thanks for the information. It seems like the GTK+ version is of very little use to me. :o I have a lot of different configurations that I want to use.
