Hello and BASIC Development
daftspaniel
Post by daftspaniel »
Hi Folks,
Just signed up and thought I would come in and say hello! Like most people on here, I imagine, I had a Dragon in the 80's as a home computer. From time to time I fired up a PC emulator to play 'Quest' or something similar. Recently I discovered the excellent XROAR and have had lots of fun playing with it. Particularly fun to try out the hardware I never had (disks + Dragon 64). I've found the Up2date disk magazine is a good read and even found one of my programs (NIM) on issue 10 which was a blast from the past :-)
Anyway, I was thinking it would be good to do some Dragon BASIC programming again - possibly a graphic minigame I started for a Java 4k contest. I was wondering if the forum had any suggestions on how best do this on an emulator? I was thinking of using something like Rainbow Writer to get more text on screen or is there a clever was to use a PC Editor and copy the text across?
Take care,
Davy Mitchell
Re: Hello and BASIC Development
XRoar will load in ASCII BASIC files directly if they have a .asc or .bas extension, so you can edit stuff in a normal text editor, then load it in as-is.
You might prefer to use the latest snapshot (the 2011 dated one here) as it fixes a bug with reattaching tape files that could otherwise make testing quite frustrating.
(Oh, and try AUDIO ON before loading CAS or ASCII BASIC files for new horrible noise reproduction ;) ).
Hi Davy,
Welcome to the forum! :)
daftspaniel
Thanks Steve and Sixxie ;)
I have got that working well - PMODE3 here I come...
Davy
daftspaniel
That build of XRoar also fixed my joystick issues - thanks again ;)
Davy
sixxie wrote:You might prefer to use the latest snapshot (the 2011 dated one here) as it fixes a bug with reattaching tape files that could otherwise make testing quite frustrating.
Just as I was about to post about the text in xroar-snap-20110106-windows32 appearing fainter than in previous versions, I notice that you have released xroar-snap-20110110-windows32 which fixes this issue. Well done!
RoyCoates
Post by RoyCoates »
sixxie wrote:(Oh, and try AUDIO ON before loading CAS or ASCII BASIC files for new horrible noise reproduction ;) ).
Oh how this made me laugh! It's been far too many years since I heard that noise!
Wonderful - thank you :)
Roy.
