Compusense. Dasm/Demon
I'm looking for an original ROM dump from Compusense's Dasm/Demon assembler/monitor cartridge.
Re: Compusense. Dasm/Demon
How do you create a cartridge ROM dump? Is it a case of CSAVEM "DASMROM", x, y, 0 and if so what are the values of x and y?
Yes, that's correct.
The required syntax for saving a 8K ($C000 to $DFFF) cartridge is CSAVEM"DASMDEM",49152,57343,35725
The required syntax for saving a 16K ($C000 to $FEFF) cartridge is CSAVEM"DASMDEM",49152,65279,35725
Please save to cassette as a 16K cart (or 8K cart if you know for sure its only 8K), convert to.CAS file, and attach the .CAS file to your reply. I can convert the .CAS file to .ROM format myself.
This may take a while, I am having a bit of difficulty creating a CAS file.
I have managed to create a CAS file, but I am unable to test it properly so it may not be perfect. If you can create a ROM from it, you can test DEMON by typing EXEC &HC000.
- DASM_DEMON-CAS.zip
- (6.37 KiB) Downloaded 452 times
Thank you for taking the time to perform this task. The following BASIC program returns a checksum of 829736 under T3 and XROAR emulation. Is this checksum correct?
10 CSUM = 0
20 FOR I = 49152 TO 57343:CSUM = CSUM+PEEK(I):NEXT
30 PRINT CSUM
You mean I have to retrieve my Dragon and DASM/DEMON cartridge after I've put them away earlier today and type in the above?
If you are happy to do so.
That's the checksum I get, so I'm now off to scan the manuals.
Thanks Alastair! I have posted the cartridge .rom file in the Uploads forum.
