0.1uf caps(104z)
thecaver99
0.1uf caps(104z)
Post by thecaver99 »
are the ceramic disc caps that are around the ic's which are labeled as 104z which are 0.1uf ceramic caps @16v, will any 104(0.1uf) cap fit the bill even thou they are smaller now days.
i have a couple that are broken and need to be replaced but i am struggling to find ones that are the same physical size but the 5mm ones are common, and are 25v.
Re: 0.1uf caps(104z)
Higher voltage fine.
As simple bypass caps I don't think you need to worry about the material either.
I used 100V X7Rs as they happened to be cheapest.
thecaver99
thanks, i have some 0.1uf already so will give them a go
Just a warning...I don't think you need to populate all of them.
