ASM6809 conditional compiling
is there any way to add a conditional clause to control an INCLUDEBIN command?
The condition should be the existence of that file in the compilation folder, for instance
	IF EXIST "SONG01.PT3"
	      includebin "SONG01.PT3"
	ENDIF
By now it doesn't work. The file is never included when ASM6809 compiler is called
Maybe I am forgetting about a parameter that allows this construct?
Any hint would be really appreciated
Re: ASM6809 conditional compiling
By now, I have overcome the problem with a very long construct affecting the caller and the source file
to be copiled, doing this
- In the caller
@set flagmus=0
if exist "SONG01.PTM" @set flagmus=1
if exist "SONG02.PTM" @set flagmus=2
if exist "SONG03.PTM" @set flagmus=3
if exist "SONG04.PTM" @set flagmus=4
if exist "SONG05.PTM" @set flagmus=5
if exist "SONG06.PTM" @set flagmus=6
if exist "SONG07.PTM" @set flagmus=7
if exist "SONG08.PTM" @set flagmus=8
if exist "SONG09.PTM" @set flagmus=9
if exist "SONG10.PTM" @set flagmus=10
asm6809 -3 -D -v --define NSONGS=%flagmus% --define MPI=1 --define COCO=0 --l=%1.LSD.ASM --o=%1.BIN %1.ASM
And then in the file to be compiled, added at the end of the text.ASM
DataBeg
	IF NSONGS > 0
		includebin "SONG01.PTM"
	ENDIF
	IF NSONGS > 1
		includebin "SONG02.PTM"
	ENDIF
	IF NSONGS > 2
		includebin "SONG03.PTM"
	ENDIF
	IF NSONGS > 3
		includebin "SONG04.PTM"
	ENDIF
	IF NSONGS > 4
		includebin "SONG05.PTM"
	ENDIF
	IF NSONGS > 5
		includebin "SONG06.PTM"
	ENDIF
	IF NSONGS > 6
		includebin "SONG07.PTM"
	ENDIF
	IF NSONGS > 7
		includebin "SONG08.PTM"
	ENDIF
	IF NSONGS > 8
		includebin "SONG09.PTM"
	ENDIF
	IF NSONGS > 9
		includebin "SONG10.PTM"
	ENDIF
EndPgm	equ	*
That way the data beginning is always at the same place ($3000) and the end is calculated
upon the length of the included songs.
Hi Pere,
Could you make use of the following batch commands to create a file called 'files.inc' that can be included in the main assembly?
echo ; files to include > files.inc
for %%f in (*.PTM) do echo   include.bin "%%f" >> files.inc
asm6809 ...
Note the extra spaces between 'echo' and 'include.bin' to make asm6809 directives instead of labels.
sorchard wrote: Tue May 30, 2023 3:38 pm Hi Pere,
asm6809 ...
Excellent, Stew!
I thought of using the 'for' construct, but did not got the smart idea of using 'echo' to add the include directives!
Thanks a lot
