I've just installed Ubuntu 12.04 and would also like to install XRoar.
I've downloaded the source, however when trying to run ./configure i'm seeing the following error :
Checking for makeinfo >= 4.13 ... no
Checking for texi2pdf ... no
Checking for install ... yes
Trace mode included
Accurate video enabled
Accurate audio enabled
Creating config.mak and config.h
Erk! No feature able of providing video output has been configured.
There's probably no point in building until you sort this out.Code: Select all
sudo apt-get install gnome-core-devel build-essentialhowever still no luck...
Please could someone guide me in how to get this running on Ubuntu 12.04
p.s. what Linux distro's are you guys using to run XRoar?
Thanks
A
