A C compiler that can compile for dragon 32?
lukeoftheaura
Post by lukeoftheaura »
is there a C compiler available (for linux preferably) that can compile for the dragon 32?
Thanks,
luke
Re: A C compiler that can compile for dragon 32?
Hi Luke!
Maybe gcc 6809 is what you're looking for.
Also, Pierre Sarrazin has developed a 6809-generating cross-compiler for a subset of the C language.
http://perso.b2b2c.ca/~sarrazip/dev/cmoc.html
The website says `The most significant difference between CMOC and a complete C compiler is the absence of longs and floats and of the const keyword.'
I'm not very knowledgable about such things but thought I'd post a link in case it was of interest? :)
Of course it's of interest!
I've tried a couple of times to compile gcc6809 without luck, so maybe this one will come in handy.
Thanks, mate!
lukeoftheaura
Bosco wrote:Also, Pierre Sarrazin has developed a 6809-generating cross-compiler for a subset of the C language.
I'll certainly give this a look - compiling gcc6809 seems like a bit of a pain.I wonder if there's a graphics library?
I know CMOC supports inline assembly language. Handy I guess for sections of code which are speed critical.
I think Rick Adams wrote `Temple of Rom' using a mix of C and ASM?
lukeoftheaura
So far I've managed to write the classic "Hello world" program using CMOC and run it on xroar and I'm quite impressed, but I don't know how to then convert that so I can run it on real hardware (to cas or WAV). any ideas?
lukeoftheaura
I can't seem to make bin2cas work, there's probably an option I'm missing.
I have this program:
#include <cmoc.h>
int main()
    printf("HELLO WORLD!\n");
    return 0;
I compile it using
cmoc main.c
and when I open the bin with xroar, I get the expected output. Then, I run bin2cas to convert to a cas file, and cas2wav to convert to cas:
./bin2cas.pl main.bin -omain.cas
./cas2wav main.cas main.wav
Then when I open the wav or the cas in xroar it seems to load the file but then nothing happens (it stays on the screen saying "F MAIN"), and I get the same response when I load it on my dragon 32.
Hi Luke,
Try my DrBinCas program which you can find here.
Tell me if you have any problem with it.
