Jet Set Willy Codes
plonsdale
Jet Set Willy Codes
Post by plonsdale »
I'm looking for an image of the casette tape sleeve with the colour codes to start the game. Either that or a cracked CAS file which bypasses the code entry!
Paul Lonsdale.
Re: Jet Set Willy Codes
Attached....Will check that the one in the downloads is the original and then add this one...
Jsw.cas
(33.45 KiB) Downloaded 749 times
Vato
Post by Vato »
Simon,
I just tried the one in "Downloads", and it was the "original" with a loading screen that requires the codes. So if this one is "cracked" it should be uploaded to the archive as well.
Vato
Tom
Done...both original and hacked versions are now available.
Here's an original copy of Manic Miner in .CAS format. The archive's current .CAS file is a hacked copy.
Manic_Miner.zip
(359.33 KiB) Downloaded 717 times
Thanks... all updated now
