Autoboot for floppydisk
redblueflame
Post by redblueflame »
Hi everyone !
To raise awareness in the Dragon 32/64, I'm currently trying to auto boot floppy that aren't bootable.
After some days, I have only three solutions:
  • Making a list of .bin names for each software and game available in this format (This is by far the longest solution)
  • Implementing the DIR routine from DOS in the host system to get the name of the file (I think this is the hardest solution)
  • Finding a way to do it on the DOS side, with a basic program, or a machine code one. For basic, afaik it seems impossible to interface with the DIR command, to get a list of files or a string with the result of the command.
As you can see, I don't have any great and easy solution.
So after all this background, is it possible to interface with the DIR command, with a specific DOS or a .bin file ?
Thanks in advance,
Redblueflame
bluearcus
Re: Autoboot for floppydisk
Post by bluearcus »
Hi RedBlueFlame,
Reading the directory entries can be done from BASIC by getting raw disk sectors in the directory area using the DragonDOS sector read commands.
SREAD is the command, and it takes a drive number, track number and sector number, and two string variables as parameter:
SREAD 1,20,3,S1$,S2$
it drops the specified sector into two strings, each 128 characters in length.
Information on the disk format can be found here:
http://dragon32.info/info/drgndos.html
That should be enough to get you some directory information out into your menu program. Autobooting (rather than running a selected program) is a different matter. There are some threads on that here I think and on the Facebook group.
Kind regards,
Mike
if you want a disk to autoboot, that is autostart a program, then you need to use a DOS that offers this feature
else you will need to issue the command BOOT instead. Right now I just remember the Eurohard DOS4.1 having that feature
Next step will be saving the program you want to be autostarted on a disk. You could then use a program that will write into the
boot area, in sector 3 (just using 256 bytes). The program I am talking about can start from the boot area any basic program
as well as any binary file.
Not sure if it is in the archive, so I am attaching here a zip file that contains an VDK with the basic program that does the trick,
I hope this could be of help!
BOOT v1.1 (1985)(MHSoft).zip
(1.48 KiB) Downloaded 551 times
