Dismantling a Dragon 32 Cartridge?
Rink
Post by Rink »
Me again. ;-)
Just wondering if anyone knows an easy way to dismantle a Dragon 32 cartridge? Obviously the screw is simple enough to remove :lol: but at the card edge end, there seems to be two sealed bolt type things. Don't want to drill them out if there's an easier way that I'm ignorant to.
rolfmichelsen
Re: Dismantling a Dragon 32 Cartridge?
Post by rolfmichelsen »
I have always used a box cutter, extending the blade quite far, and just cut the two "bolts" when doing things like this. Leaves no visible marks on the outside of the cartridge case, and you can always glue it together later if you really want to.
Rink
Post by Rink »
Cheers Rolf, it looks like that was working just fine. However, it was taking ages with the shitty blade I have, so I ran out of patience and ended up drilling them. :) That proved to be far more painless than I imagined.
