Pirate Adventure by Scott Adams
This is my own modified version of "Pirate Adventure" by Scott Adams. The following changes were made to the original game:
(1) The game no longer (irritatingly) asks "DO YOU HAVE LOWERCASE?" when running on a Dragon 32/64.
(2) The game automatically enables lowercase mode if you answer yes to the above question when running on a CoCo.
(3) Improved keyboard response when running on a Dragon 32/64.
(4) Replaced the custom loader/copy protection/auto-run with a more conventional auto-run.
Pirate Adventure (1983)(Scott Adams)(Zephyr)[!].zip
(29.18 KiB) Downloaded 322 times
Sarah
Re: Pirate Adventure by Scott Adams
Post by Sarah »
zephyr wrote:(1) The game no longer (irritatingly) asks "DO YOU HAVE LOWERCASE?" when running on a Dragon 32/64.
That does appear to prevent (for example) the lower-case support built-in to T3 being used, though!
This updated version solves that problem. :)
DRAGON 32/64 AND LOWERCASE TEXT
There has never been a real Dragon 32 or 64 made that has true lowercase letters. However, if you have a Dragon which has been modified to display lowercase or want to play the game under T3, PC-Dragon, etc emulators using the inbuilt lowercase function, then follow these instructions:
(1) Start the emulator with Dragon 32 or 64 emulation (or power-up your modified Dragon).
(2) Enable the emulator's (or hardware modified Dragon's) lowercase letter display.
(3) Enter CLOADM at the command prompt and press the CAPS LOCK key (or Shift+0 on your hardware modified Dragon).
(4) Press ENTER and wait for Pirate Adventure to load from cassette.
Note: The game's lowercase letters (inverse text) can be toggled on/off by the CAPS LOCK key at any time during gameplay (Enter "LOOK" to refresh the whole display).
Pirate Adventure (1983)(Scott Adams)(Zephyr)(v2)[!].zip
(29.61 KiB) Downloaded 365 times
