64K Upgrade
64K Upgrade
Could someone please post the 64K upgrade information for the Dragon 32. I had this document, but can no longer find it. :cry:
vdc300
Re: 64K Upgrade
Post by vdc300 »
No problem
I have performed the upgrade, so I know it works. I got hold of a dragon 32 with the piggy back memory board, so it was "reasonable" easy, I would advise a really good solder sucker and a temp controlled iron.
The upgrade is from an article in up2date, which I thinks awaiting re-listing on this site?!. It's few years since I did it, but then, parts could be purchased from JAMECO, although the postafe was a fortune (from the states), I found a much cheap place, where the postage was very cheap and fast!
I'll post them on.
Re: 64K Upgrade
All issues of the Up2Date disk magazine are available in the downloads area:
http://archive.worldofdragon.org/archiv ... Up-2-Date/
Quite a few to check to find the article..
vdc300
Re: 64K Upgrade
Post by vdc300 »
Thanks for the update, Admin
Sparkplugs! the doc is a scanned image pdf, so is big, 6MB zipped, so I can't upload.
Will work on it
futurlec was the company with the cheap postage!
vdc300
Re: 64K Upgrade
Post by vdc300 »
Here is the first 3 pages
Re: 64K Upgrade
vdc300 wrote:Thanks for the update, Admin
Will work on it
Vdc300, Simon, thanks taking the time to help with this. Vdc, could you please upload the pdf to http://www.sendspace.com/, http://files.mail.ru/eng, http://localhostr.com/, or rapidshare, and post the download link here.
Re: 64K Upgrade
I am working on some sort of upload facility for the site - if you can email it, send it to simon.hardy@atosorigin.com and simonhatdy72@yahoo.co.uk - both should accept attachments upto 10Mb in size and I will host in the download area of this site (and add it to the Wiki)
Re: 64K Upgrade
Simon, I managed to find the 64K upgrade document. :) I have mailed it to the address above.
Vdc, you can remove those large .jpg files from this thread now.
Re: 64K Upgrade
OCR'd, 90% edited and online in the Wiki.
Re: 64K Upgrade
That's much better. 8-) The original PDF document was not so easy on the eyes.
Thanks Simon! :D
