Apples by Bob Crispen
This is a copy of the game "Apples" by Bob Crispen.
Description by L. Curtis Boyle.
Apples is a game where you try to collect all the apples in a maze. You have a running timer, and a creature that starts in the opposite corner of the maze, who will start moving around after the timer reaches a certain point. Using the fire button on the joystick, you also have the ability to blow up the walls immediately surrounding you on four sides (diagonally from your position has no effect). This allows you to modify the maze slightly as you go through it.
Apples (1982)(Bob Crispen)[!].zip
(12.58 KiB) Downloaded 265 times
