Hi Ciaran!
I was testing my dump of Manic Miner and it loads ok in XRoar but, when I press enter to play, it just shows random data on screen and hangs.
The dump works ok on a real Dragon. The same behaviour occurs with the dumps in the archive.
I'm using XRoar 0.27 on Windows 7 64 bit.
Funny enough, it works on the same version in my Linux Mint 12 under virtualbox... I don't remember whether it's 64 bit or not.
Manic Miner problem on XRoar
Re: Manic Miner problem on XRoar
Well that was an interesting one - I had to git bisect to discover that's down to what happens to the data bus when the CPU fetches from an address that no device handles. DarrenA pointed out that the bus tends to indicate the last thing that was on it (probably the fetch instruction itself), and that behaviour's been built into XRoar since 2010 (version 0.24-ish). Except it's always been a bit lacking - it wasn't updated during "dead" CPU cycles.
I've pushed some snapshot builds fixing this, but I'm going to have to trace through Manic Miner and find where it accesses empty memory (maybe it's trying to check for a cartridge present as part of its copy protection or something).
I just tried my own copy and the cracked version of Manic Miner from the archive and they both work fine. Tested on XROAR versions 0.24, 0.27, and 0.28 with the following command line under 32-bit Windows XP.
I have attached both copies for test purposes.
EDIT: Attachment removed.
xroar -vo sdl -machine dragon32 -extbas d32.rom -nodos -kbd-translate
Oh I only just noticed the 32/64 bit implication...
I'm not even sure I have easy access to any machines with a 32-bit OS, but even so, that fix has nothing to do with word length. Very weird.
Tracing through, it runs this:
Where it proceeds to deliberately blat memory. Amusing! And indeed caused by my short-cut in the NVMA code: the NVMA after each instruction should put the same value on the data bus (from the top byte of ROM) in each case, and they'd compare. My short cut meant that the "bus" read $01 for the LDA and $02 for the CMPA.
Here's the discussion about what ends up on the data bus, with DarrenA pointing out what's going on here.
But what on earth in my code could produce a different result on a 32-bit machine? I'm a little confused by that.
Edit: Zephyr: looks like both your versions are cracked, they skip the code input stage entirely, which means they probably also omit that little bit of "protection" too.
Edit edit: also, actually I guess I will have a 32-bit OS - but it'll be Mac OS X on PowerPC, so may not prove anything.
3f7c| b6c001 LDA $c001 cc=f0 a=01 b=00 dp=00 x=4c99 y=4937 u=19aa s=05f8
3f7f| b1c002 CMPA $c002 cc=f9 a=01 b=00 dp=00 x=4c99 y=4937 u=19aa s=05f8
3f82| 10260001 LBNE $3f87 cc=f9 a=01 b=00 dp=00 x=4c99 y=4937 u=19aa s=05f8
Yes, just checked and that test for the presence of a cartridge is bypassed in both versions. When Robcfg wrote "The same behaviour occurs with the dumps in the archive" I assumed he had tried them all. No problems running that code under Dragon 32 emulation under XROAR 0.24 and the latest 0.28 snapshot with 32-bit Windows XP.sixxie wrote:Edit: Zephyr: looks like both your versions are cracked, they skip the code input stage entirely, which means they probably also omit that little bit of "protection" too.
Yep, such anti-social behaviour from a popular game was pretty silly and begging to be cracked! I hated ever having to remove ALLDREAM...sixxie wrote:Where it proceeds to deliberately blat memory. Amusing!
That's just begging for a blow by blow accountSarah wrote:Yep, such anti-social behaviour from a popular game was pretty silly and begging to be cracked! I hated ever having to remove ALLDREAM...
Hi guys!
I tried zephyr's version and runs dandy on my setup.
Also, here you have my dump, it works ok in a real dragon and loads in Xroar (on my machine) up to the point where it freezes.
- Manic Miner (1984)(Software Projects Ltd)[!].zip
- (14.46 KiB) Downloaded 450 times
It runs perfectly for me under the latest XROAR 0.28 snapshot (xroar-snap-20120509-w32). Try the attached version...robcfg wrote:Also, here you have my dump, it works ok in a real dragon and loads in Xroar (on my machine) up to the point where it freezes.
My version works with the latest XRoar snapshot, thank you!
And the last zephyr version works with my standard 0.27 setup...
