Loading files into Xroar....
Hi All,
Is there a way of loading files that have a DragonDos header into Xroar....not here I don't mean from a disk image! Files in theis format are what the DragonMMC uses for files saved direct to the FAT filesystem with MLOAD / MSAVE. The format of the header is :
Byte(s) Purpose
$00 Start marker ($55)
$01 File type, $01=Basic, $02=Binary
$02-$03 Load address
$04-$05 Length
$06-$07 Exec address
$08 End marker ($AA)
MAME / MESS can't load these files natively, but a version with the debugger enabled I can drop to the debugger console and use the load command to load the file at load address - header len with something like :
load rgbtest.dgn, 6ff7,400
In this case the load address was $7000 with the second number being the maximum number of bytes to load.
Is there a way of doing this in XRoar?
Pernod70
Re: Loading files into Xroar....
Post by Pernod70 »
prime wrote: Fri Jul 19, 2019 11:21 pm MAME / MESS can't load these files natively, but a version with the debugger enabled I can drop to the debugger console and use the load command to load the file at load address - header len with something like :
I could easily add native support for these using the Quickload option. Can you post a couple of sample files?
Just use File->Load or File->Run. XRoar recognises initial $55 (in a file with ".bin" extension) as DragonDOS and parses the header. You should then find it in memory...
(FWIW, if it sees an initial $00, it tries it as a CoCo RS-DOS binary instead)
Oh, and BASIC files not supported yet... Should probably look into that!
Pernod70 wrote: Sat Jul 20, 2019 2:18 am
Sure here you go :
DGNFiles.zip
Test files
(11.71 KiB) Downloaded 428 times
ROMMELS.DGN is the Game "Rommel's Revenge"
RGBTEST.DGN is my graphics mode tester.
Both are filetype binary.
sixxie wrote: Sat Jul 20, 2019 8:47 am Just use File->Load or File->Run. XRoar recognises initial $55 (in a file with ".bin" extension) as DragonDOS and parses the header. You should then find it in memory...
Yeah that worked when I renamed them to bin. Would it be possible to add the extensions .DGN and .CCO so this format is recognized in files with those extensions, as that is what DragonMMC uses by default.
Would make testing things on emulators easier...... :)
prime wrote: Sat Jul 20, 2019 7:22 pm Yeah that worked when I renamed them to bin. Would it be possible to add the extensions .DGN and .CCO so this format is recognized in files with those extensions, as that is what DragonMMC uses by default.
Possibly... .dgn is searched for when looking for system ROMs (in case someone only has the headered versions required by PC-Dragon/T3), but it's actually not registered as normal file format to "load", so nothing stopping it having different meanings in the different contexts.
Straw poll though: does anyone actually rely on .dgn files for their system ROMs? Has anyone ever relied on them?
..ciaran
Sarah
Post by Sarah »
Yes all my ROM files are that format. :lol:
Haha :)
But presumably even you keep headerless versions around for MAME - which I don't think ever respected your authoritah in that regard...
Sarah
Post by Sarah »
I've never used it; to be honest I'm not following recent emulators & don't know what they support.
Well, no reason to get rid of the search for .dgn when finding ROMs (or the header skipping).
But also I guess no reason to stop .dgn and .cco being handled the same as .bin.
Snapshots here...
..ciaran
