Grosvenor AX25 and AMTOR
dlinsley
Location: Seattle, USA (formerly Chester-le-Street, UK)
Post by dlinsley »
Includes the ROM dump and some photos of both the inside and outside of the cartridge.
Grosvenor AX25 and AMTOR.zip
(834.67 KiB) Downloaded 541 times
Pernod70
Re: Grosvenor AX25 and AMTOR
Post by Pernod70 »
Has anyone taken a look at this?
Considering it's a 32K ROM I'd assumed that the switch would simply select which half is paged in so that each program can be called with EXEC 49152. This doesn't seem to be the case so I'm wondering if they've switched some data lines to obfuscate the code. Need to take a closer look at the photos.
Pernod70
Post by Pernod70 »
Success! The ROM is definitely encrypted.
The address lines A0 and A1 are swapped, and the switch selects which half of the ROM is addressed with line A14.
The data lines are also swapped in order MSB 3, 2, 1, 0, 7, 6, 5, 4 LSB.
