Yes! I’m super happy about that!I see it's been merged
MAME Emulation
Re: MAME Emulation
Re: MAME Emulation
If you download and compile the latest code from gothub yes. If you don’t want or can’t compile it, you’ll have to wait for the next official version.
Re: MAME Emulation
ok just done a little testing.
MESS158
COCO2 - Left and Right Joystick movement and Buttons work ok with 2 player Monkey King.
DRAGON32 - Has no Analogue option to configure. So no joystick control at all - nothing.
key "8" still acts as LEFT fire button, starting game.
MAME197
COCO2 - Right Joystick - has no control moving LEFT. Up, Down, Right, Fire. are ok.
Left Joystick - all good.
DRAGON32
LEFT controler - movement ok, no FIRE button. key "8" still works as FIRE in emulated keyboard mode.
so maybe????
COCO2 and Dragon32 joystick code is ever so slightly different (typo).
Xroar Joystick LEFT control is working for me.
so you could check that source code and compare for any obvious control differences.
Re: MAME Emulation
just done further testing.
recompiled MAME 202 with just Dragon and COCO2 machines.
***removed Joysticks from USB ports in PC.
enable 2 joysticks in MAME config.
remap keys for left analogue joystick (W,S,A,D,\).
control works with both machines in left and right ports (using keyboard to control).
the default joystick key settings for Dragon Right & Left ports both use NUMPAD 8 for Up.
however "8" also acts as the fire button in a LEFT port game.
so that is a conflict.
and "7" also acts as fire button in RIGHT port games (not a problem in most games).
With COCO2 same setup.
There is no conflict with numpad 8. 7 or 8 do not act as fire buttons.
in Analogue control options, there is an extra setting that Dragon doesn't show enabled MOUSE X, MOUSE Y.
control works perfect using remapped or default keyboard.
going to test with alternate joystick ports enabled/disabled.
Re: MAME Emulation
Finally solved!
Problem is the default keymap/joystick settings MAME uses.
even when the Joystick port is set to "Unconnected".
to enable FIRE in LEFT joystick.
you MUST enable RIGHT Joystick, and remap all controls to NONE.
This testing also found another problem.
SPACE seems to be disabled to start a keyboard game in Caverns of Chaos.
which does work in Xroar.
- left working 1.PNG (20.28 KiB) Viewed 92802 times
- left working 2.PNG (43.57 KiB) Viewed 92802 times
- left not working 1.PNG (22.92 KiB) Viewed 92802 times
- left not working 2.PNG (16.2 KiB) Viewed 92802 times
Re: MAME Emulation
your sample pics look very nice.robcfg wrote: ↑Mon May 06, 2019 8:54 pm I've created a pull request to add my changes to MAME's source code: https://github.com/mamedev/mame/pull/4980
but when i recompile the latest source code from GITHUB, the artifacting looks broken.
this is what i see now, and before...
maybe i did something wrong?
- artifact-new.png (3.22 KiB) Viewed 92792 times
- artifact-old.gif (5.02 KiB) Viewed 92792 times
Re: MAME Emulation
That’s how it’s supposed to look like.
If you want to see the red-blue artifacting, start a Dragon Tano machine, which is ntsc.
Re: MAME Emulation
AH!, i see.
I can't (don't want) to believe that WHITE is going to be darkish grey, and BLACK a weird shade of dark green as the MAME standard from now on.
my eyesight is bad enough.
Is there a way we could possibly have both colour settings available, say with an option in the Artifacting TAB?.
i do prefer a pixel sharp image with true red,green,blue,white,black if possible.
Please take no offence with this request.
I really appreciate the time and effort you put into it.
- Dunjunz.png (963 Bytes) Viewed 92775 times
- 0001.png (1.24 KiB) Viewed 92776 times
Re: MAME Emulation
No offense in any way, and a very valid point indeed.
The palette I put in is closer to the real thing so, just in emulation terms is the one that should be there.
I don’t think MAME, or most emulators out there, were designed with accessibility in mind. That said, it may be worth to raise the question on the dev forum.
Meanwhile, as you can compile it, I suggest you just copy the old palette values on top of the new ones and compile it again.
Later today, I can point you to the right place to look for it.
