MACRO on ASM6809
MACRO on ASM6809
I would like to create a macro that should use a long branch or a short branch
upon the distance to the target label.
Say something like this:
IF (a00100 - (*+2) > 127) ; a00100 is the label where execution should branch if condition satisfied
lbeq a00100
ELSE
beq a00100
ENDIF
How could I create a macro that would receive TWO parameters: the condition Type and the destination label (both as strings)
for instance used that way: CONDJMP beq a00100 ; macro - condition - destLabel
CONDJMP MACRO
IF (\2 - (*+2) > 127) ; adding two because pointer will be already past compare line
"l"\1 ; l in front of condition to create a long branch
ELSE
\1
ENDIF
ENDM
When I compile this, I get a double error message
syntax error: TESTSPEED.ASM:9: no positional variables on stack
syntax error: TESTSPEED.ASM:11: no positional variables on stack
Does anybody know the right way to declare and use a macro with 2 parameters?
Any hint would be highly appreciated
Re: MACRO on ASM6809
Hi Ciaran,
using this definition
CONDJMP MACRO
IF ( (\{1}-(*+2)) > 127)
lbeq \{1}
ELSE
beq \{1}
ENDIF
ENDM
and using it this way CONDJMP "a00100"
This is the result I get in the .lst file
1BCD CONDJMP "a00100"
1BCD 10270000 lbeq \{1}
ELSE
beq \{1}
ENDIF
No way to use the parameter I pass to the macro , see the parameter is used as a number with value zero ...
And I would like to use it as is: a Label that will be processed by ASM6809 accordingly ...
Any idea of how to solve that?
Thanks in advace
Hi Pere,
To answer your second question, you can specify the jump destination without quotes to pass it by value:
CONDJMP a00100
Your first question is more difficult. I've tried before and failed to pass an instruction as a macro parameter. I think it's possible to supply a string to be used as part of a label, or to be placed inside another string for example in an FCC statement, but I've not had any success supplying an instruction as a parameter.
sorchard wrote:Hi Pere,
CONDJMP a00100
Hi Stew,
you are right, Kees and me have been working on that macro idea and have ended with a 'solution' as you are proposing:
The label is passed as a number (no quotes) and then the instruction as a string, which is then used in a fcb statement to form the
conditional followed by a FCB or FDB upon short/long branch with the calculated (by ASM6809) distance LABEL - * (refined with -1 or -2)
and the numeric comparison using the label works well ...
Thanks a lot
LWASM has an`auto branch length' option which is kind of nice.
Maybe something for a future ASM6809 update? :)
