The ROMs included in the attached archive have been patched with my 63x09e error trapping support and Steve Woolham's keyboard auto-repeat routine. Use the included RPT-ON.CAS/RPT-OFF.CAS to enable/disable keyboard auto-repeat.
Patched versions of CoCo 2/3 NTSC and PAL ROMs are included. Also included is a copy of the v1.42 vcc.exe Windows executable with the same patches applied to its internal CoCo 3 BASIC ROM code.
EDIT: Attachment removed.
CoCo 2/3 Patched ROMs
Re: CoCo 2/3 Patched ROMs
After some experimentation I discovered that my original 63x09e error trapping support was not as effective as I had hoped it would be. The attached v2.0 ROMs have been updated with improved 63x09e error trapping support.
- CoCo2&3_Patched_ROMs_v20.zip
- (265.79 KiB) Downloaded 452 times
