Music software for the dragon?
lukeoftheaura
Post by lukeoftheaura »
Does any music software (sequencers etc) exist for the dragon? I know of one program called "music maker" but I can't figure out how it works - and documentation seems nonexistant. I also know synther7 which is a cool synth, but doesn't have any kind of sequencing.
snarkhunter
Re: Music software for the dragon?
Post by snarkhunter »
I'm not sure Microdeal's "The Dragon Composer" could be what you're looking for, but I would still suggest checking that one first. I believe the original documentation will be available.
BR,
Lionel
lukeoftheaura wrote:Does any music software (sequencers etc) exist for the dragon? I know of one program called "music maker" but I can't figure out how it works - and documentation seems nonexistant. I also know synther7 which is a cool synth, but doesn't have any kind of sequencing.
Hi, I am attaching here the manual I found about this program
There are other options ... for instance Orchestra90 that allows entering scores for up to 5 voices
The manual exists for the CoCo, but you could use the Dragon version from these two threads:
viewtopic.php?f=5&t=5515 --- main thread about this port
viewtopic.php?f=5&t=5622 --- latest version to work on a Tandy MPI
And a last chance, I think that there were some music apps running under OS-9 despite they could be CoCo oriented too ...
Music_Maker - manual.zip
(223.64 KiB) Downloaded 304 times
lukeoftheaura
a lot of this software seems to be disk-based, and I have no access to a disk drive.
yes, composer X is disk based. Synther 7 seems to be a kind of soft that doesn't fit your needs.
Orchestra is a ROM based program that works both with tapes and disks
Music Maker exist in cas version, I am attaching it here
lukeoftheaura
pser1 wrote:Hi,
Music Maker (1986)(John Penn Discount - David Makin).zip
I have music maker, but I have no idea how to use it - I can't find any documentation.
pser1 wrote:Hi,
have you tried with the manual I uploaded previously in this thread? ... I see nobody has yet downloaded it :-(
pser1 wrote: (Music Maker)
Is the manual for a different version? It talks about menu options that don't seem to exist... And trying to adjust the "play shift" after loading one of the examples, it's not clear how you select specific channels to apply it to.
I have never used this program.
I enclose in a zip all of the info I have about it, hope this could help ...
Music Maker.zip
(411.36 KiB) Downloaded 300 times
