Buzzard Bait Cracked - Wave File
Below is a wave file created from the misnamed "Buzzard Bait (1984)(Microdeal)[cr].zip" found in http://archive.worldofdragon.org/archiv ... Microdeal/ it has been tested in XRoar but not yet on a real Dragon. Unlike the other cracks, this version retains the "Tom Mix" loading screen.
BuzzardBaitCracked.zip
(106.38 KiB) Downloaded 616 times
Admin please note. As mentioned above "Buzzard Bait" was by Tom Mix and not by Microdeal, therefore all versions should be labelled as such and the .cas files should reside in the Tom Mix downloads section.
Re: Buzzard Bait Cracked - Wave File
... or both. It was *distributed* by Microdeal here, and I think they even created the dongle.
drmarkb
Post by drmarkb »
Alastair wrote:Below is a wave file created from the misnamed "Buzzard Bait (1984)(Microdeal)[cr].zip" found in http://archive.worldofdragon.org/archiv ... Microdeal/ it has been tested in XRoar but not yet on a real Dragon. Unlike the other cracks, this version retains the "Tom Mix" loading screen.
I tried it last night, along side Tee Off, on a real dragon (Tano was the one out) using a cassette copy of the Wav- loaded perfectly.
