GDB users curious as to why write watchpoints never triggered in XRoar unless there was also some sort of read watchpoint may like to update to the latest point release, 0.34.7
Bit of a brown paper bag one, that.
Small fix to XRoar's GDB support
Re: Small fix to XRoar's GDB support
I can't use gdb under Linux. Is there a way to build GDB-6x09? I have to use an EXE-file with Virtual Box. Thanks.
Oh, strange, I used to have a (working!) git repo on my site, seems to be gone.
I'll have to find the latest local copy and re-push.
Either way it's stuck being based on GDB version 7.6, because its architecture changed a fair bit after that and I never put the time into redoing.
Ok the git repo is there, I just hadn't pushed out any branch with the name stated on the web page...
If you follow the instructions at http://www.6809.org.uk/dragon/m6809-gdb.shtml, you should get a working native m6809-gdb.
gcc -g -O2 -I. -I. -I./common -I./config -DLOCALEDIR="\"/usr/local/share/locale\"" -DHAVE_CONFIG_H -I./../include/opcode -I./../opcodes/.. -I./../readline/.. -I../bfd -I./../bfd -I./../include -I../libdecnumber -I./../libdecnumber -I./gnulib/import -Ibuild-gnulib/import -DTUI=1 -I/usr/include/python2.7 -I/usr/include/python2.7 -Wall -Wdeclaration-after-statement -Wpointer-arith -Wformat-nonliteral -Wno-pointer-sign -Wno-unused -Wunused-value -Wunused-function -Wno-switch -Wno-char-subscripts -Wmissing-prototypes -Wdeclaration-after-statement -Wempty-body -c -o gdb.o -MT gdb.o -MMD -MP -MF .deps/gdb.Tpo gdb.c
In file included from gdb.c:19:0:
defs.h:105:17: fatal error: bfd.h: No such file or directory
#include "bfd.h"
compilation terminated.
Makefile:968: recipe for target 'gdb.o' failed
make: *** [gdb.o] Error 1
Odd, working here, from a clean checkout.
bfd/bfd.h (from the top level) is a generated header file from earlier in the build process.
If you type (again from the top level):
What's the output?
If nothing, try rm bfd/stmp-bfd-h first...
make -C bfd bfd.h
Wow! It works! The problem was in the command cd gdb - it must be cd binutils-gdb.
Whoooops! Build instructions left over from using a different git repo
I'll update!
I'll update!
