Getting a good picture from the monitor port
kerbingamer376
Post by kerbingamer376 »
I bought a monitor cable for my dragon, and plugged it into my TV, and came across a problem, the picture is always blurring and changing colour. Any help?
Re: Getting a good picture from the monitor port
Hi!
It would be nice if you can take a little video of the screen problems so it's easier to identify the cause.
Also, it would be nice if you could open your Dragon and take a picture of the boards inside. Later Dragon 32 boards had a fix for the video signal which was included in the Dragon 64 design.
