HiText disk image as requested
vdc300
Post by vdc300 »
As requested here is a disk image of Hi-Text by Mathew Lodge.
hitext00.vdk
HiTEXT disk works with D32/D64
(720.02 KiB) Downloaded 509 times
Re: HiText disk image as requested
Thank you very much!
A question though. The disk is a standard 5.25" disk? How did you image the disk?
vdc300
Post by vdc300 »
Hi
Good question, I've only just got the kit up and running again to allow an image of a real drive. I was messing around with Vcopy(DOS) and cocoreader(Windows). I think VCOPY reported errors, although it copied the files across. So to be on the safe side I may have moved them to another blank VDK.
I'll check the original and post of photo of the label.
Paul
