BTW, don't worry, I'm not trying to buy it from you.
Cumana disk system
Cumana disk system
Does anyone have in their possession a Cumana disk controller with Cumana DOS V2.0?
Re: Cumana disk system
I have a cumana disk controler. I shall look it up as its at my parents place. Do you need the rom image?
Yes, that's exactly what I need.
Long time ago that I booted everything. What poke did I need so the cartridge wouldn't load automatically? I remember also to csavem from adres x to y, z
Do you have the params?
If I can boot stuff I certainly will check all the disks. They still were working in 2002
The following params will save a copy of the entire cartridge area from $C000 TO $FEFF. You shouldn't need to disable DOS for this to be successful, but if you do have any problems, use Steve Woolham's Cartridge Detach program to disable DOS first.Gestel wrote:Long time ago that I booted everything. What poke did I need so the cartridge wouldn't load automatically? I remember also to csavem from adres x to y, z
POKE144,2:CSAVEM"CDOS20",49152,65279,35725
Download Cartridge Detach here: http://www.geocities.com/ukdragon32/
In the mean time I found this between my stuff. Is it working/helpfull?
CumanaDos2.dgn- (11.02 KiB) Downloaded 551 times
It certainly triggered a subtle coding bug in my FDC code: now fixed, so thanks!
Edit: Possible Windows build available here: http://www.6809.org.uk/tmp/da/xroar-0.2 ... dows32.zip - sorry, it's completely untested even in Wine, as it seems the NVidia 32-bit compat libs are currently broken in Debian testing.
I once downloaded it. Never tried wether it was working. So if isn't working I always can put the original (in my possession) rom on CAS/DGN
For the record:I'm using XP
If I rename CumanaDos2.dgn to one of the standardnames of the manual eg: DDOS10.DGN and copy that to the directory of Xroar-0.23pre2-Windows32; the Cumana DOS v2.0 starts Ok!
One of the things I will have to do is make a copy of the cumana dos manuals!
Nice!!
Nice!!
