Rescued old Dragon games
digging among old 'compilation' tapes from the 80's I have rescued a few programs
that I will upload here.
The files are from 60 minutes tapes, so no manual, no inlay card .... just a WAV file
so that you could use it in a real Dragon.
Sometimes the WAV contains more than a file that are loaded sequentially by the first
program when run/executed ...
Caterpillar Cave (1983)(T&D Software - A. Pakerski).zip
(1005.94 KiB) Downloaded 455 times
Apples (1982)(Bob Crispen).zip
(2.56 MiB) Downloaded 445 times
Re: Rescued old Dragon games
This one is a special one ...
It is an editor-assembler-degubber that works for Dragon 32
and on a Dragon64 it switches to map1 and gives 51k of free RAM
The 'con' is that it only supports TAPE
I know that I had a manual for it ... should I find it, then I will upload it here too
EDIT1: I am adding the manual in pdf format and an image of Microdeal's tape
CORES64 (Microdeal) - TAPE.zip
(91.95 KiB) Downloaded 438 times
CORES64 (Microdeal) -Manual.zip
(4.33 MiB) Downloaded 435 times
Cores64D (1983)(Cer-Comp - Bill Vergona - Microdeal).zip
(4.82 MiB) Downloaded 446 times
Cool!
Thank you very much!
I'll take a look at them when I finish Sir Randolf XD
This is a translated version of "Dragon Selection 2" made by Eurohard for the spanish market.
I have uploaded the files individually as the whole tape was too big (it failed 1st attempt)
EDIT1: I am adding here two images, one for the tape itself an another for the inlay
Dragon Selection 2 - Tape and Inlay.zip
(317.98 KiB) Downloaded 435 times
06-YANKEE (Dragon Selection 2)(Eurohard) (song for 05).zip
(510.66 KiB) Downloaded 444 times
05-MUSICA (Dragon Selection 2)(Eurohard) (run).zip
(2.21 MiB) Downloaded 427 times
04-DATA (Dragon Selection 2)(Eurohard) (data for 02 & 03).zip
(763.24 KiB) Downloaded 418 times
03-INDEX (Dragon Selection 2)(Eurohard) (run).zip
(2.21 MiB) Downloaded 440 times
02-DRAGON (Dragon Selection 2)(Eurohard) (run).zip
(1.27 MiB) Downloaded 442 times
01-DATABASE (Dragon Selection 2)(Eurohard) (run).zip
(2.07 MiB) Downloaded 435 times
this is next block of wav files ...
Orbitroids (1982)(Creative Computing Software).zip
(1.83 MiB) Downloaded 437 times
Inspector Clueseau (1983)(Eurosoft).zip
(5.25 MiB) Downloaded 431 times
Ice Master (1983)(Arcade Animation).zip
(3.96 MiB) Downloaded 460 times
and that completes the first wave ...
The program Tarot is translated into spanish, I don't know the source for it
despite it could be french (?)
The worksheet is painfull and written in Basic ...
Tarot, cartas del (198x)(Software Editores) (SP).zip
(5.7 MiB) Downloaded 436 times
Sheety (aka Visicalc) (1984)(Sqren Roug).zip
(1.99 MiB) Downloaded 426 times
