I just wanted to share an interesting project I have had the chance to work on.
I would like to program for the module Wordpak2+ (color VIDEO cartridge fro Dragon / CoCo)
and this is going to be imposible to be debugged with GDB.
It will need to be debugged on the fly, so right on the Dragon machine.
I just had heard about an application that allows doing that: NoICE from John Hartman
http://www.noicedebugger.com
I contacted John to get that program, he was very kind and sent me the program and a license ... thanks a lot!
It is a nice Windows debugger, for quite a lot of different CPUs and microcontrollers.
The monitor for CoCo exists, so I modified it to work with our Dragon64 using the serial port at 19200 bauds.
In order to be able to debug ROM areas, it is mandatory to work in MAP1 (all RAM), so I have coded the monitor
to load from $FA00 on. I attach here the source and the binary of my 'modified' monitor for Dragon-6809
Debugging a real Dragon with NoICE - serial port
- Dragon6809 Monitor x NoICE v2.0.zip
- (9.15 KiB) Downloaded 1136 times
Re: Debugging a real Dragon with NoICE - serial port
just some pictures - screenshots of the debugger on the PC and the monitored Dragon64
I just came across this thread... wow, another excellent Dragon tool!
To make it even more worthwhile, the NoICE author loves the 6809 and 6309 so much that, unlike every other CPU the project supports, he will offer the license for 6809 and 6309 for free if you simply email him and let him know about your project.
Supercool.
Mike
Supercool.
Mike
Hi Mike,
if I remeber correct, I contacted John Hartman when I was wanting to have a 'debugger', to ask him for permission
and he gently sent me a free license to use the software so that I could make a Dragon version.
And he gave me permission too to upload the software here for anyone who wanted to use it ...
I should say, anyway, that I have not yet used it again
Usually I do debug the programs on XRoar even if they use the HD6309
Hi Pere,
I think it's probably most useful for real hardware scenarios, as you say. I have been looking for a real hardware options for some time, and this looks useful. I understand also that there is a Nitros9 module, though whether it can work in L1 may be an issue, but it's a very interesting prospect!
Kind regards,
Mike
Kind regards,
Mike
HI Mike,
there is another possible candidate ...
Do you know the Godil project?
There is a version that emulates the 6809 so that you could trace everything that it does ... you'll find info here
https://github.com/hoglet67/AtomBusMon/wiki/ICE-6809
Oh that project looks awesome - so basically, it's a plugin 6809 emulator? I can't imagine myself every doing anything hardcore enough to justify this, but I'm tempted anyway
I've used the Godil based emulator, and it is indeed excellent, being able to supend the CPU and look at registers / memory / single step is
indeeed useful.
There is anew version that has a proper level translator board and a cheapish FPGA development board.
indeeed useful.
