WANTED: Dragon to TV Cable
homeschooldragon
Post by homeschooldragon »
I managed to get an okay signal from my Dragon to the TV using a standard sized coax cable however I had to wedge the cable in one place as it looks like the original cable had a smaller diameter cable at the Dragon end.
Can anyone point me in the right direction of a correctly sized replacement please?
Many thanks.
10 CLS
20 PRINT "HELLO"
30 GOTO 20
Re: WANTED: Dragon to TV Cable
The Dragon end of the tv cable is a phono plug.
Something should turn up if you search for "dragon rf cable" on ebay.
If your TV has a composite image input or SCART socket then you could also try looking for a 5 pin DIN (for the monitor socket round the back of the Dragon) to whatever your TV accepts cable.
Rolo
Post by Rolo »
It's really just an ordinary CINCH-connector. But better follow Alastair's solution and go for a DIN-5 (180°) to SCART-cable!
