Dragon Power
binaryprose
Dragon Power
Post by binaryprose »
Can anyone recommend a good replacement psu for the Dragon32? or failing that a toroidal transformer of the correct rating that will fit into the psu case?
Steven
p.s.
has anyone cracked one open? whats inside?
Re: Dragon Power
There's some discussion here:
viewtopic.php?f=5&t=5394
munkeyboy
Re: Dragon Power
Post by munkeyboy »
I can't help with a suitable replacement, but I do have some pictures of the oblong power brick.
Dragon power supply.jpg (127.11 KiB) Viewed 8569 times
Dragon power supply 2.jpg (102.19 KiB) Viewed 8569 times
Dragon power supply 3.jpg (112.83 KiB) Viewed 8569 times
Dragon power supply 4.jpg (85.18 KiB) Viewed 8569 times
Re: Dragon Power
Thanks, first time I see the inside of a Dragon power brick! So was there a fuse in there? That question came up in another thread.
Re: Dragon Power
Yes, cheers for the photos.
That looks very much like a thermal fuse on the primary winding in the last photo.
Re: Dragon Power
Thanks, that sates half of my curiosity - there still remains the square power brick.
munkeyboy
Re: Dragon Power
Post by munkeyboy »
My curiosity has been raised about the square brick as well.....hmmm I do have a dead square brick in the loft somewhere :roll: . I'm sure my curiosity will only grow.
Gareth
norris
Re: Dragon Power
Post by norris »
munkeyboy wrote:My curiosity has been raised about the square brick as well.....hmmm I do have a dead square brick in the loft somewhere :roll: . I'm sure my curiosity will only grow.
Gareth
munkeyboy
Re: Dragon Power
Post by munkeyboy »
Thank's Norris, much clearer pictures than the ones I took.
So, it appears that the only real difference is the case design. I haven't opened up my dead brick yet, or even found it, but I will open it to see if it is repairable, if I notice any differences to this one then I will of course post my findings.
Cheers, Gareth
norris
Re: Dragon Power
Post by norris »
munkeyboy wrote:Thank's Norris, much clearer pictures than the ones I took.
Cheers, Gareth
Taken with my Nokia windows phone(lumina 930) but needs resizing however if you save it image you will see it at a normal size.
Trying to get it repaired.
I now have three Dragons (32s).
