Hello Ciaran,
I have been using the last snapshot and worked great ...
But it failed when I wanted to debug a program using the GDB
The message says something like:
Files that give a description of the problem:
C:\Users\serrat\AppData\Local\Temp\WERD5F8.tmp.WERInternalMetadata.xml
C:\Users\serrat\AppData\Local\Temp\WERECE3.tmp.appcompat.txt
C:\Users\serrat\AppData\Local\Temp\WERED8F.tmp.hdmp
I am attaching them 'zipped' here, maybe this could help.
You can count on me to do any needed test
Ps Of course, version "v0.33.1-2015-33312 w64" works flawlessly
XROAR and Windows 10
Re: XROAR and Windows 10
- Crash-Files.zip
- (2 MiB) Downloaded 237 times
Now that I've fixed my Wine fonts issue (none appearing, even with fonts-wine package installed - fix was to use winetricks), I can look into this - first quick test showed gdb working though - both w32 and w64. Is there anything you do other than starting with -gdb and then connecting to it to trigger this?
Hello Ciaran,
this is the bat file I use to start both GDB and XRoar:
This bat works flawlessly with the old XRoar "v0.33.1-2015-33312 w64"
cd..
copy ..\XRoar\DOS-ROMs\dplus50.rom ddos40.rom
copy ..\XRoar\ROMs\d64rom1V31.rom d64_1.rom
copy ..\XRoar\ROMs\d64rom2V31.rom d64_2.rom
start xroar -gdb -machine dragon64 -machine-cpu 6309 -extbas d64_1.rom -altbas d64_2.rom -machine-cart dragondos -cart-rom ddos40.rom -force-crc-match -disk-write-back -joy-left 0,0:1:0 -kbd-translate -lp-file ..\XRoar\sortida.txt
pause "press any key when XRoar is running"
m6809-gdb -ex "layout asm" -ex "layout regs" --eval-command="target remote localhost:65520"
del *.rom
Hello Sixxie,
I am uploading here a zip file that contains the environment where I test this last version.
Just execute the .BAT file
I have put inside a folder two screenshots, one before executing a program (1 byte) in XRoar
and the other with the crash
In the Windows event viewer I have found just this small file with info about the problem.
If your exe does save info into another folder, just tell me and I will upload it here too
- XRoar-Test.zip
- (2.9 MiB) Downloaded 238 times
Unfortunately all of that works fine under Wine - not crashing for me!
Do you have the .hdmp (mdmp?) file from running this version? winedbg seemed to be able to do something with those, and it might give me a clue where the crash is happening.
I have found these two files inside a folder.
I have zipped the whole folder and attached it here
Hopefully this will help find the problem
- AppCrash_xroar.exe.zip
- (2.23 MiB) Downloaded 231 times
Hi Ciaran,
I have seen on "http://www.6809.org.uk/tmp/xroar/"
a new snapshot of XRoar (2016-15132) from yesterday ...
I have downloaded it and it works without GDB, but as soon as it is
intercepted by GDB crashes as did last snapshot ...
I assume I wil have to wait untill you tell me it works again with GDB.
If you need me to do any test, just let me know. Thanks.
Yeah sorry, that was just a snapshot that killed off Control+C in the SDL interface for someone else (long since undocumented, doesn't work in the GTK+ interface).
I've not made any progress on the gdb weirdness - wine doesn't give me anything useful with your last set of mdmp/hdmp files I'm afraid.
- Gareth_O'Flaherty
The latest iteration of Windows and XRoar now working perfectly with one another! Happy days.
Got my first Dragon 32 in 1983 (where does the time go??).
Sounds like the move to SDL2 is a big win for Windows then.
Shame about its keyboard handling: extra platform-dependent code is required to handle special characters like Ñ on the Dragon 200-E in translated mode. SDL1 made that pretty straightforward.
