Dragon 200e character set ...
I was just contemplating the Dragon 200e character set here - http://www.6809.org.uk/tmp/xroar/d200e.png - and I was wondering if anyone knew what the characters 44 and 45 were for? (if I've counted them correctly). I note that 44 also appears under the OK - is it a strange cursor? Why's there a version with no top?
Thanks! Tony
Re: Dragon 200e character set ...
Hi Tony,
these are the cursors!
One for normal (uppercase) while the other is used to design you are working in lowercase ...
shift+Intro switches from lower-uppercase
