Windows build
Nothing new since the snapshot builds except an update to the docs, but here's what changed since the last release:
- Speed improvements.
- New pseudo-ops: SET, FCN, FCS
- Strings may contain \r and \n (\\ to escape a backslash).
- Permit ASCII strings to be used as integer values (8 bits per char).
- Support relational operators between string values.
- Fix indirect single-arg forward references.
The psuedo-ops and string interpolation mirror what's found in lwasm, just for portability.
Comparing two strings does what you expect - it's only when combining a string with integer operations that an ASCII value to integer conversion is performed.
And yes, this incorporates the fix to the stupid jmp [fwdref] bug!
