daftspaniel
Post
by daftspaniel »
Good Evening!
Well after a near complete rewrite (HTML Tables weren't cutting it) here is a update to the screen designer based on your awesome feedback
http://daftspaniel.com/Dragon/JSTools/S ... gner4.html
Updates:
* Keyboard shortcuts
* Unlimited Undo
* Click and hold to 'paint' and moving mouse doesn't select stuff.
* Optional Grid
* CLS confirmation
* Assembly Output - only tested with Sixxie's PERL based assembler
I've only tested on Chrome and Firefox so there may be some browser bugs.
Next update will feature the other block shapes and inverted text!
Davy
Post
by tjewell »
Great new version, thanks very much - and can't wait for the future updates either!
Tony.
Post
by Alastair »
Davy, I can't get this new version to work. Does it require HTML 5 ?
daftspaniel
Post
by daftspaniel »
Hi Alastair,
No HTML5 in it (yet!) - what browser/OS are you using? I've been busy installing browsers and testing for the next update.
Thanks,
Davy
Post
by Alastair »
Thanks Davy, the update works with SeaMonkey 2.0.14 as well (which is the version I currently use).
