Attached is the newsletter of above, Vol 7 - Aug 87
cm
Dragon Amateur Radio User Group newsletter
ChickenMan
- Contact:
- dragon_arug_vol7_87_08.zip
- (444.21 KiB) Downloaded 516 times
Re: Dragon Amateur Radio User Group newsletter
Awesome!
I'll try to get some time and type the programs and generate a VDK image.
Thanks a bunch!
Thanks a bunch!
ChickenMan
- Contact:
One simpler way is to cut and paste the PDF to a Text editor and then just edit it. They have been OCR'ed but its not perfect, only about 90% correct, maybe less, as the originals were very light in contrast and what you see there is the best I could get it. I assume you can convert a Text listing into a tokonized Basic listing.
cm
cm
