Nerble Force .cas
Shock Trooper
Nerble Force .cas
Hi, is there a working .cas or .wav of nerble force for uk dragon 32. Thx.
Re: Nerble Force .cas
There's a working cas for nerble force in the downloads section:
http://archive.worldofdragon.org/archiv ... 5Bu%5D.zip
Looks like control is joystick only.
Shock Trooper
Hi, I cannot get it to work. I've tried it with dc through dropbox and cocotape through command prompt. I have converted lots of .cas files to .wav successfully from this site using dc. Thx
Hi, see if this works. It's a wav file created with the 'Rewrite' and 'Output Tape' functions in xroar.
- nerble.zip
- (67.72 KiB) Downloaded 654 times
Shock Trooper
Hi, i tried this file on my real uk Dragon and it works, thanks very much. This is a Microdeal
re-release of the Dragon Data original, plays exactly the same but i noticed the buff option mountain terrain is green
In this Microdeal version vs purple in the original Dragon Data version! I think the dragon data version was in buff only (no screen selection). Great to have a working version on my ipod now, thx.
