DragonDOS 1.0 usable bytes?
Does anyone know if any of the zero bytes from $DE3E to $DE52 in the DragonDOS 1.0 ROM are unused and safe for adding small patch routines?
Re: DragonDOS 1.0 usable bytes?
If It would help I have an assemblable dissasembily of DragonDos 1.0, though I just got that to the stage where it would re-assemble for the Dragon 32/64 and the Alpha, I also have done SuperDos E6 which has also been ported to work on the RS-DOS cart (plugged into a Dragon), as well.zephyr wrote:Does anyone know if any of the zero bytes from $DE3E to $DE52 in the DragonDOS 1.0 ROM are unused and safe for adding small patch routines?
Thanks Phill!
That should do the trick. I would love to have a copy of those.
![Cool 8-)](./images/smilies/icon_cool.gif)
Phill, did I misunderstand you?
Ok here they are...... see ReadMe.txt for instructions on building them.zephyr wrote:Thanks Phill!![]()
- DragonDosSource.zip
- DragonDos 1.0 source
- (296.51 KiB) Downloaded 290 times
- SuperDosSource.zip
- SuperDosSource
- (83.85 KiB) Downloaded 256 times
Thanks Phill!
You are a true gentleman.
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
