How does the floating point math package in BASIC work?
I still try to bugfix my Emulator: viewtopic.php?f=5&t=4308&p=11316#p11316
There is a bug somewhere related with the BASIC09 "floating point math package"...
So i try to understand how it works. I find a article "Floating Point Math" by "Steven R. Broadwater" in the The Rainbow Magazine (Radio Shack Color Computer) (February 1985) -> https://archive.org/details/rainbowmagazine-1985-02
It helps a little, but hey this is hardcore stuff for me ;)
I would like to try some simple function from the math package, as descried in the article.
I used the Simple6809 ROM. There are some equal addresses:
Floating Point Accu 0 is also stored in $0050-$0053
FPA0 Exponent in $004f and FPA Sign in $0054
FPA1 stored in $005c-$0061
I found two interesting Routines in ROM:
$e777 = CONVERT THE VALUE IN ACCB INTO A FP NUMBER IN FPA0
$e778 = CONVERT THE VALUE IN ACCD INTO A FLOATING POINT NUMBER IN FPA0
So i try to store the number "6" into FPA0 via CPU accu B:
The ASCII Number 6 is $36 so i try this:
0000   C6 36                  LDB   #$36
0002   BD E7 77               JSR   $e777
The result is:
Memory dump from $004f to $0054:
	$004f: $86 (dez: 134)   | $4f: *PV FLOATING POINT ACCUMULATOR #0 FPA0 EXPONENT
	$0050: $d8 (dez: 216)   | $50: *PV FLOAT.ACCU #0 FPA0 MANTISSA MS  Most Significant Byte
	$0051: $00 (dez: 0)     | $51: *PV FLOAT.ACCU #0 FPA0 MANTISSA NMS Next Most Significant Byte
	$0052: $00 (dez: 0)     | $52: *PV FLOAT.ACCU #0 FPA0 MANTISSA NLS Next Least Significant Byte
	$0053: $00 (dez: 0)     | $53: *PV FLOAT.ACCU #0 FPA0 MANTISSA LS  Least Significant Byte
	$0054: $00 (dez: 0)     | $54: *PV FLOATING POINT ACCUMULATOR #0 FPA0 SIGN
are this the right values?
Re: How does the floating point math package in BASIC work?
Question: What floating point format is it?
Seems that is not a a standard format, isn't it? not IEEE 754-1985 or?
Seems that the float values are stored like this:
exponent: 1Byte = 8 Bits (most significant bit is the sign 1=positive 0=negative)
mantissa/fraction: 4Bytes = 32 Bits
sign of mantissa: 1Byte = 8 Bits (0x00 positive, 0xff negative)
or not?
EDIT: Seems that's the same "format" as the C64 used, see: http://www.c64-wiki.com/index.php/Float ... arithmetic
What i not understand: Storing the sign into one byte, seems to be "extravagance"... For the information is only one bit needed, isn't it?
This is very well explained in "Inside the Dragon", section 9.3. I can recommend reading the whole book! :)
JeeK
Post by JeeK »
jedie wrote:I still try to bugfix my Emulator: viewtopic.php?f=5&t=4308&p=11316#p11316
0000   C6 36                  LDB   #$36
The result is:
Seems correct. But your assumption is wrong. Register B is taken as value (if signed integer, this will be -128 to 127) and not as a ASCII coded digit!
If I calculate the value back from the FP representation
$36 = 54
Float:
86         d8        00       00       00       00
2^(+6)
10001010   110110000 00000000 00000000 00000000 00000000
+   4+2    || ||
           || |+ 0.03125
           || +- 0.0625
           |+--- 0.25
           +---- 0.5
(0.5+0.25+0.0625+0.03125)*2^6 = 54
This float value represents decimal 54 which is hex $36, the value you stored in register B. ;)
Ah! Thanks!
tormod wrote:This is very well explained in "Inside the Dragon", section 9.3. I can recommend reading the whole book! :)
Also thanks! I found it ;)
JeeK wrote:If I calculate the value back from the FP representation
$36 = 54
Float:
86         d8        00       00       00       00
2^(+6)
+   4+2    || ||
           || |+ 0.03125
           || +- 0.0625
           |+--- 0.25
           +---- 0.5
Here is something wrong.
$86 is: 10000110 and not 10001010 (this is $8a)
Is $86 wrong or just the binary representation?
EDIT: Is this correct ?
2^(+6)
10000110   110110000 00000000 00000000 00000000 00000000
+    4     || ||
     +2    || ||
           || |+ 0.03125
           || +- 0.0625
           |+--- 0.25
           +---- 0.5
jedie wrote:What i not understand: Storing the sign into one byte, seems to be "extravagance"... For the information is only one bit needed, isn't it?
From "Inside the Dragon": It's just for speed ;)
JeeK
Post by JeeK »
$36 = 54
Float:
86         d8        00       00       00       00
2^(+6)
+   4+2    || ||
           || |+ 0.03125
           || +- 0.0625
           |+--- 0.25
           +---- 0.5
This was a typo by me. For sure, $86 is 10000110, $80 + 4 + 2 ;)
As a side note:
Most FP schemes uses an offset by $80 "biased" representation:
Value     Exp.    Value
$00         -      0 (special marker)
$01      -127      mantissa * 2^(-127)
$80         0      mantissa * 1
$FF      +127      mantissa * 2^127
This "biased rep." has the advantage that 2 values could be easily compared byte-wise like strings without the need for subtraction of both values ...
JeeK
Post by JeeK »
Basic interpreters (like MS-derived) use two representations: optimized
  • for speed in calculations (FP accumulators) the sign is separate, the leading bit of the normalized is in place
  • for space, e.g. storing values in variables or variable arrays: the sign is encoded in the first leading bit of the mantissa which is always 1, because the mantissa is normalized (starts always with 0.1xxxxx).
I have created a Python class for representing a BASIC-Float:
#!/usr/bin/env python
import math
import decimal
def unsigned8(x):
    """ convert a signed 8-Bit value into a unsigned value """
    if x < 0:
        x = x + 0x0100 # 0x100 == 2**8 == 256
    return x
class FloatingPoint(object):
    def __init__(self, value):
        self.value = decimal.Decimal(value)
        self.mantissa, self.exponent = math.frexp(value)
        self.exponent_byte = unsigned8(self.exponent-128)
        if self.mantissa>=0:
            self.mantissa_sign = 0x00
        else:
            self.mantissa_sign = 0xff
        self.mantissa_bytes = self.mantissa2bytes(self.mantissa)
    def mantissa2bytes(self, value, bytes=4):
        value=decimal.Decimal(abs(value))
        result = []
        pos = 0
        for byte_no in xrange(bytes):
            current_byte = 0
            for bit_no in reversed(xrange(1,8)):
                pos +=1
                bit_value = decimal.Decimal(1.0) / decimal.Decimal(2) ** decimal.Decimal(pos)
                if value >= bit_value:
                    value -= bit_value
                    current_byte += 2**bit_no
            result.append(current_byte)
        return result
    def get_bytes(self):
        return [self.exponent_byte]+self.mantissa_bytes+[self.mantissa_sign]
    def print_values(self):
        print "Float value was: %s" % self.value
        print "\texponent......: dez.: %s hex: $%02x" % (self.exponent,self.exponent)
        print "\texponent byte.: dez.: %s hex: $%02x" % (
            self.exponent_byte,self.exponent_byte
        print "\tmantissa value: dez.: %s" % (self.mantissa)
        print "\tmantissa bytes: dez.: %s hex: %s" % (
            repr(self.mantissa_bytes),
            ", ".join(["$%02x" % i for i in self.mantissa_bytes])
        print "\tmatissa-sign..: hex: $%02x" % self.mantissa_sign
        bytes = self.get_bytes()
        print "\tbinary........: hex: %s" % (
            ", ".join(["$%02x" % i for i in bytes])
        print "\texponent |            mantissa             | mantissa-sign"
        print "\t" + " ".join(
            ['{0:08b}'.format(i) for i in bytes]
        print
    def __repr__(self):
        return "<BinaryFloatingPoint %f: %s>" % (
            self.value, ", ".join(["$%02x" % i for i in self.get_bytes()])
FloatingPoint(54).print_values()
FloatingPoint(-54).print_values()
FloatingPoint(5.5).print_values()
FloatingPoint(-5.5).print_values()
FloatingPoint(0).print_values()
FloatingPoint(10.14**38).print_values()
FloatingPoint(10.14**-38).print_values()
with syntax highlighting -> https://gist.github.com/jedie/94f8d310bb88fdb0d188
Example output is:
Float value was: 54
	exponent......: dez.: 6 hex: $06
	exponent byte.: dez.: 134 hex: $86
	mantissa value: dez.: 0.84375
	mantissa bytes: dez.: [216, 0, 0, 0] hex: $d8, $00, $00, $00
	matissa-sign..: hex: $00
	binary........: hex: $86, $d8, $00, $00, $00, $00
	10000110 11011000 00000000 00000000 00000000 00000000
Float value was: -54
	mantissa value: dez.: -0.84375
	matissa-sign..: hex: $ff
	binary........: hex: $86, $d8, $00, $00, $00, $ff
	10000110 11011000 00000000 00000000 00000000 11111111
Float value was: 5.5
	exponent......: dez.: 3 hex: $03
	exponent byte.: dez.: 131 hex: $83
	mantissa value: dez.: 0.6875
	mantissa bytes: dez.: [176, 0, 0, 0] hex: $b0, $00, $00, $00
	binary........: hex: $83, $b0, $00, $00, $00, $00
	10000011 10110000 00000000 00000000 00000000 00000000
Float value was: -5.5
	mantissa value: dez.: -0.6875
	binary........: hex: $83, $b0, $00, $00, $00, $ff
	10000011 10110000 00000000 00000000 00000000 11111111
Float value was: 0
	exponent......: dez.: 0 hex: $00
	exponent byte.: dez.: 128 hex: $80
	mantissa value: dez.: 0.0
	mantissa bytes: dez.: [0, 0, 0, 0] hex: $00, $00, $00, $00
	binary........: hex: $80, $00, $00, $00, $00, $00
	10000000 00000000 00000000 00000000 00000000 00000000
Float value was: 169606421016759270908588940533105164288
	exponent......: dez.: 127 hex: $7f
	exponent byte.: dez.: 255 hex: $ff
	mantissa value: dez.: 0.996856948842
	mantissa bytes: dez.: [254, 152, 128, 138] hex: $fe, $98, $80, $8a
	binary........: hex: $ff, $fe, $98, $80, $8a, $00
	11111111 11111110 10011000 10000000 10001010 00000000
Float value was: 5.8960031937775952846575658526371605536051129075884808536027556193767507219429130357164845760358320471417048480589073733426630496978759765625E-39
	exponent......: dez.: -126 hex: $-7e
	exponent byte.: dez.: 2 hex: $02
	mantissa value: dez.: 0.501576480538
	mantissa bytes: dez.: [128, 50, 212, 30] hex: $80, $32, $d4, $1e
	binary........: hex: $02, $80, $32, $d4, $1e, $00
	00000010 10000000 00110010 11010100 00011110 00000000
Don't know if this all is correct.
JeeK wrote:for space, e.g. storing values in variables or variable arrays: the sign is encoded in the first leading bit of the mantissa which is always 1, because the mantissa is normalized (starts always with 0.1xxxxx).
Then it looks simmilar to the C64 example here: http://www.c64-wiki.com/index.php/Float ... on_example
But here the Exponent is calculated with: 152 - 129 = 23
But Inside Dragon says an page 232: 128 must be subtracted.
