Modern storage option...
If a modern storage option for the Dragon where being developed say SD/MMC based, what would people want it to support ?
Ideas so far :
Loading / saving of .cas files from the card ?
Loading / saving of Cartrige files from the card ?
Native loading / saving / file access ?
Dos emulation ?
Any others ?
Re: Modern storage option...
I guess "loading and saving from disk files" comes under "DOS emulation" right?
Is there any program that needs several disks inserted at the same time. The DOS controllers can manage up to 4 drives , but I'm not sure if that is really necessary.
Would it be possible for it to create memory dumps so that you can save, and load, snapshots of whatever you are working on (or playing) at any time?
Alastair wrote:Would it be possible for it to create memory dumps so that you can save, and load, snapshots of whatever you are working on (or playing) at any time?
I have thought about doing this, and on the face of it, it seems a simple thing to do, however it's complicated by a few things.
To work such a system would have to not only dump the memory but would have to restore the exact state of the CPU and peripheral chips as well.
For the CPU this is easy enough as it would probably be interrupt triggered, and you could get the CPU registers from the stack.
For the 6821's the I/O, DDR and control registers are readable so that would be ok, and since the VDG is configured through the 6821s, then that
should be OK.
However the big problem is the SAM as it's configuration registers are read-only so capturing them may be a problem, which may lead to a snapshot
not working, I may be able to get the programable logic chip to capture these if there is enough spare logic, but I can make no promises.
robcfg wrote:I guess "loading and saving from disk files" comes under "DOS emulation" right?
One of the things I would like to do is modify one of the Dos roms to work with this interface, so yeah you would be able to mount virtual disks and use them.
I see no reason why it could not support 4 disks.
Sarah
Post by Sarah »
This is pretty much the basis of an article entitled Double Dragon that I put together for Dragon Update long ago (reproduced below with source code and updated attributions). It features a task manager that can clone the first 32K of a Dragon 64 to make an approximation of 2 x Dragon 32s; using special key combinations you can effectively snapshot one Dragon 32 over the other and also switch between them on-demand.
As you say... there are problems with doing this, so it's far from perfect, although the technique actually works pretty well for BASIC programs.
DOUBLE DRAGON
Here's a short and simple program which enables you to run more than one program at once on your Dragon. Or more precisely, Task Swapper turns an unexpanded Dragon 64 into two separate Dragon 32's. You can therefore develop and RUN two BASIC programs simultaneously. Or perhaps run BASIC on one virtual machine whilst at the same time using ALLDREAM or playing a game of ESCAPE on the other.
To change between the tasks just press SHIFT and SPACE. You can do this at any time; you do not need to be at the command prompt. The active and inactive tasks are then swapped and you can continue from where you left off in the other task. You can also press SHIFT+O to overwrite the inactive task with the active task, thereby saving your position in an adventure game or making a back-up copy of a program which you are working on. You can also use this facility to bring a crashed task back into use.
To install the Task Swapper program simply enter, save and then RUN the BASIC loader given below. You then have two identical virtual machines, and can continue and switch between them as you please. But what architectures do you now have? Well, both machines must share the IO registers, use a new IRQ handler, and lose the 330 bytes of memory occupied by Task Swapper. But apart from these restrictions the illusion of two separate machines is complete.
In practice this means that if you run BASIC on both virtual machines then you should have no problems at all. However, you must not attempt to access the upper 32K of RAM, or CLEAR/POKE above address $7EB5. It's also wise to avoid switching tasks in the middle of IO operations such as printing.
For machine code programs the issue of compatibility with Task Swapper is more complicated. In theory they should work just as well. However, the lack of a protection mechanism in the 6809 means that Task Swapper cannot prevent other programs from taking over the IRQ. And if this happens then the inactive task will become inaccessible (though sometimes pressing RESET may reinstate Task Swapper). Most commercial games will indeed monopolise the IRQ, and only trial and error can reveal which programs are compatible.
Some machine code programs also use non-standard base addresses for the graphics screen and so will not be restored correctly when swapped back into main memory. For such programs simply press SHIFT+G to scroll the screen up, or SHIFT+W to scroll down. You only need to do this once, as addresses $BA:$BB are updated accordingly. Semigraphics and obscure graphics modes aren't supported at all.
To avoid conflicts with machine code programs Task Swapper may be relocated if necessary. It can happily live anywhere in RAM but must begin on an even byte boundary. I've not tested Task Swapper under Dragon DOS, but it may work. I'd guess that it would be prudent to access disks from just one of the tasks, or perhaps modify Task Swapper so that the DOS workspace isn't swapped.
100 'Dragon 64 Task Swapper by Sarah
110 CLEAR 200,&H7EB5: L=&H7EB6
120 READ A$: FOR I=1 TO 66 STEP 2: V=VAL("&H"+MID$(A$,I,2)): T=T+V
130 POKE L,V: L=L+1: NEXT: IF L<32768 THEN 120
140 IF T=37631 THEN EXEC &H7EB6 ELSE ?"Error In Data"
200 DATA 338C5E11B3010D260D39000000000000010000000000BE010DAF8D00F8FF010D33
210 DATA 8D011B9E72AF8D011EDF728680347E340210EF8CD48D0C3BEC81EDC11183FF0025
220 DATA F6391A10B7FFDF9E8ACE80008DED308CAD33898000308901008DE0B7FFDE396A8C
230 DATA AC26378EFF008605A78CA2E602867FA702A684E7028548260C10EF8C8A8DC2F6FF
240 DATA 22E78C8D855026060ABA0ABA2008854426090CBA0CBA1700892075856026711A10
250 DATA 10EF8DFF62328DFF67B7FFDF308DFF4BAF8DFF559E8A108E80008D5E30890100CC
260 DATA 8000ED8DFF428D51B7FFDEA68DFF403402F6FF22E78DFF37BDA93AA6E481B0251B
270 DATA CEFFC081C0250EA74581D0250C81E02506A7432004A743A7418D243502B7FF22AE
280 DATA 8DFF0110EE8DFEFAAF8DFEF67E0000EC84EEA4EDA1EF81AC8DFEEB25F239DCBA44
290 DATA 8EFFC64424063001A7802004A78430028CFFD425EE3912308DFF1DBF010D7E0000
7EB6
7EB6            * TASK SWAPPER BY SARAH
7EB6            * 15/4/94
7EB6
7EB6            *CHECK IF ALREADY INSTALLED
7EB6 338C5E     @START LEAU IRQ,PC
7EB9 11B3010D    CMPU $10D
7EBD 260D        BNE INSTAL
7EBF 39          RTS
7EC0
7EC0            *S REGISTER SWAP SPACE+STACK ETC
7EC0 0000       SREG   FDB 0
7EC2 0000       SREG2  FDB 0
7EC4 0000       END    FDB 0
7EC6 01         IRQCNT FCC 1
7EC7 00000000   STACK  FDB 0,0
7ECB 00         FF22   FCC 0
7ECC
7ECC            *INSTALL NEW IRQ HANDLER
7ECC BE010D     INSTAL LDX $10D
7ECF AF8D00F8    STX IRQJMP+1,PC
7ED3 FF010D      STU $10D
7ED6
7ED6            *INSTALL NEW RESET HANDLER
7ED6 338D011B    LEAU RESET,PC
7EDA 9E72        LDX 114
7EDC AF8D011E    STX RESJMP+1,PC
7EE0 DF72        STU 114
7EE2
7EE2            *FORK AND RETURN
7EE2 8680        LDA #$80
7EE4 347E        PSHS U,Y,X,DP,D
7EE6 3402        PSHS A
7EE8 10EF8CD4    STS SREG,PC
7EEC 8D0C        BSR DUP
7EEE 3B          RTI
7EEF
7EEF            *COPY LOOP
7EEF EC81       CPLOOP LDD ,X++
7EF1 EDC1        STD ,U++
7EF3 1183FF00   COPY CMPU #$FF00
7EF7 25F6        BLO CPLOOP
7EF9 39          RTS
7EFA
7EFA            *COPY MEM TO EXTENDED MEMORY
7EFA 1A10       DUP ORCC #$10
7EFC B7FFDF      STA $FFDF
7EFF 9E8A        LDX $8A
7F01 CE8000      LDU #$8000
7F04 8DED        BSR COPY
7F06 308CAD      LEAX @START,PC
7F09 33898000    LEAU $8000,X
7F0D 30890100    LEAX $100,X
7F11 8DE0        BSR COPY
7F13 B7FFDE      STA $FFDE
7F16 39          RTS
7F17
7F17            *NEW IRQ HANDLER
7F17            *TIME TO READ KEYBOARD YET?
7F17 6A8CAC     IRQ DEC IRQCNT,PC
7F1A 2637        BNE IRQJP2
7F1C
7F1C            *READ KEYBOARD
7F1C 8EFF00      LDX #$FF00
7F1F 8605        LDA #5
7F21 A78CA2      STA IRQCNT,PC
7F24 E602        LDB 2,X
7F26 867F        LDA #255-128
7F28 A702        STA 2,X
7F2A A684        LDA ,X
7F2C E702        STB 2,X
7F2E
7F2E            *CHECK FOR SHIFT+O
7F2E 8548        BITA #64+8
7F30 260C        BNE NOVER
7F32 10EF8C8A    STS SREG,PC
7F36 8DC2        BSR DUP ;OVERWRITE OTHER TASK
7F38 F6FF22      LDB $FF22
7F3B E78C8D      STB FF22,PC
7F3E
7F3E            *CHECK FOR SHIFT+W
7F3E 8550       NOVER BITA #64+16
7F40 2606        BNE NDOWN
7F42 0ABA        DEC $BA
7F44 0ABA        DEC $BA
7F46 2008        BRA CHGBAS
7F48
7F48            *CHECK FOR SHIFT+G
7F48 8544       NDOWN BITA #64+4
7F4A 2609        BNE NUP
7F4C 0CBA        INC $BA
7F4E 0CBA        INC $BA
7F50 170089     CHGBAS LBSR GBASE
7F53 2075       IRQJP2 BRA IRQJMP
7F55
7F55            *CHECK FOR SHIFT+SPACE
7F55 8560       NUP BITA #64+32
7F57 2671        BNE IRQJMP
7F59
7F59            *PREPARE TO SWAP TASKS
7F59 1A10        ORCC #$10       ;NO MORE IRQS
7F5B 10EF8DFF62  STS SREG2,PC    ;REMEMBER STACK
7F60 328DFF67    LEAS STACK+4,PC ;TEMP STACK
7F64
7F64            *SWAP THE TASKS
7F64 B7FFDF      STA $FFDF
7F67 308DFF4B    LEAX @START,PC
7F6B AF8DFF55    STX END,PC
7F6F 9E8A        LDX $8A
7F71 108E8000    LDY #$8000
7F75 8D5E        BSR SWAP
7F77 30890100    LEAX $100,X
7F7B CC8000      LDD #$8000
7F7E ED8DFF42    STD END,PC
7F82 8D51        BSR SWAP
7F84 B7FFDE      STA $FFDE
7F87
7F87            *SWAP THE DISPLAY MODE
7F87 A68DFF40    LDA FF22,PC
7F8B 3402        PSHS A
7F8D F6FF22      LDB $FF22
7F90 E78DFF37    STB FF22,PC
7F94 BDA93A      JSR 43322
7F97 A6E4        LDA ,S
7F99 81B0        CMPA #$B0
7F9B 251B        BLO TEXT
7F9D
7F9D            *SET GRAPHIC RESOLUTION
7F9D CEFFC0      LDU #$FFC0
7FA0 81C0        CMPA #$C0
7FA2 250E        BLO X11
7FA4 A745        STA 5,U
7FA6 81D0        CMPA #$D0
7FA8 250C        BLO XXX
7FAA 81E0        CMPA #$E0
7FAC 2506        BLO XX1
7FAE A743        STA 3,U
7FB0 2004        BRA XXX
7FB2 A743       X11 STA 3,U
7FB4 A741       XX1 STA 1,U
7FB6
7FB6            *SET BASE ADDRESS
7FB6 8D24       XXX BSR GBASE
7FB8
7FB8            *SET VDG REGISTER
7FB8 3502       TEXT PULS A
7FBA B7FF22      STA $FF22
7FBD
7FBD            *SWAP STACK POINTERS
7FBD AE8DFF01    LDX SREG2,PC
7FC1 10EE8DFEFA  LDS SREG,PC
7FC6 AF8DFEF6    STX SREG,PC
7FCA
7FCA            *CONTINUE EXISTING IRQ HANDLER
7FCA 7E0000     IRQJMP JMP >0
7FCD
7FCD            *MEM AND EXTENDED MEM SWAP LOOP
7FCD EC84       SWLOOP LDD ,X
7FCF EEA4        LDU ,Y
7FD1 EDA1        STD ,Y++
7FD3 EF81        STU ,X++
7FD5 AC8DFEEB   SWAP CMPX END,PC
7FD9 25F2        BLO SWLOOP
7FDB 39          RTS
7FDC
7FDC            *SET SCREEN BASE ADDR. FROM $BA
7FDC DCBA       GBASE LDD $BA
7FDE 44          LSRA
7FDF 8EFFC6      LDX #$FFC6
7FE2 44         SETADR LSRA
7FE3 2406        BCC SET0
7FE5 3001        LEAX 1,X
7FE7 A780        STA ,X+
7FE9 2004        BRA TSTEND
7FEB A784       SET0 STA ,X
7FED 3002        LEAX 2,X
7FEF 8CFFD4     TSTEND CMPX #$FFD4
7FF2 25EE        BLO SETADR
7FF4 39          RTS
7FF5
7FF5            *NEW RESET HANDLER
7FF5 12         RESET NOP
7FF6 308DFF1D    LEAX IRQ,PC ; ENSURE IRQ SET
7FFA BF010D      STX $10D
7FFD 7E0000     RESJMP JMP >0
8000
drag0n
Post by drag0n »
prime wrote:If a modern storage option for the Dragon where being developed say SD/MMC based, what would people want it to support ?
Ideas so far :
Dos emulation ?
Any others ?
I'd really like to see NitrOS9 support.
Perhaps a modified version of the coco's HDB-DOS, now that its source has been released: http://roms.coco.l-w.ca/hg/index.cgi/fi ... hdbdos.asm
Rink
Post by Rink »
Coverflow of installed tapes?
Just kidding. :D
(BTW That's not a coverflow from my iTunes library - I like Blondie but the rest... yuk)
