Dragon Setup
Dragon Setup
Hi.
I bought a cheap Dragon 32 recently, eagerly hooked it up to a CRT TV, (via an old RF cable), and tried loading a WAV from my Android tablet. Unfortunately this didn't work, although why I'm not sure. I tried loading at different volume settings but the Dragon didn't appear to be picking up an audio signal. I checked I was using the correct jack. I guess it could just be a faulty cassette tape lead? It is pretty ancient.
So before I start buying replacement cables etc, I wondered how other users have their Dragons setup for the 21st century?
Is anyone successfully loading WAVs from a tablet/media player?
Also I've seen Dragon `5Din to SCART' TV leads available. Should I get one of these or is there something better?
Bosco.
Re: Dragon Setup
I feed tape audio from the headphone socket of a netbook all the time. But I've fed such audio from many computers - it's never been a problem.
Well, it has been a problem, because I use Linux, and Mr. Poettering has conned lots of people into accepting a really horrible and variable experience - especially if you use Um-Bongo, it's basically a coin toss as to which of Pulse or ALSA (which is directed through Pulse, yet somehow exhibits different characteristics) will work properly - but that's a rant not relevant here... ;)
In general, audio out from a PC should be fine. Is it possible your tablet is screwing with the audio somehow? Maybe capture some into a PC using Audacity and see if the waveform looks right.
Re: Dragon Setup
Hi sixxie.
Sounds like it should work then. I'll play about with it some more.
How about video? What kind of display/connection is your Dragon using?
Re: Dragon Setup
At the moment, a small LCD television - a fairly old Philips one. Does an ok job, although it rounds the edges of the pixels in a rather odd manner.
Re: Dragon Setup
Bosco wrote:How about video? What kind of display/connection is your Dragon using?
See here: viewtopic.php?f=5&t=4875
Re: Dragon Setup
Cool, thanks for the info.
Just noticed Retro Computer Shack sell composite video A/V leads for the Dragon. Should do the trick. :)
drmarkb
Re: Dragon Setup
Post by drmarkb »
Exactly what I use for mine, from the same company.
Works really well on a 1990's portable, but also really fine with a modern 26 flats screen TV too, if you adjust the TV's settings as they will probably be miles out.
As for audio, I use........cassette tape. :lol: I have the dragon set up in a room without a PC (I call it the Dragon Suite, the wife calls it the spare bedroom!).
Re: Dragon Setup
Made me chuckle. :D
Re: Dragon Setup
For display solutions, these threads can also be interesting:
viewtopic.php?f=3&t=4276 Hello from another new member
viewtopic.php?f=5&t=518 Dragon and VGA Monitor
viewtopic.php?f=8&t=4712 Connecting a Dragon to a vga monitor.
viewtopic.php?f=5&t=4603 Has anyone any monitor recommendations?
Re: Dragon Setup
Cool, thanks for the links. :D
