File Formats
File Formats
Hi.
Can anyone run through what's required to make CAS and WAV files?
I'm currently using LWASM which outputs DECB, OS9 and raw binaries but I haven't succeeded in turning any of these into a working CAS/WAV.
Many thanks.
Re: File Formats
You can convert raw binaries to CAS files with robcfg's DrBinCas utility.
viewtopic.php?f=8&t=348&hilit=drbincas
Convert CAS files to Wave files with Ciaran's (sixxie) cas2wav utility.
viewtopic.php?f=7&t=354
Re: File Formats
Hi zephyr.
Had a play with DrBinCas (v0.4b) a while back but couldn't get a CAS file that ran properly from LWASM raw files.
Just tried another test. I've attached copies of the raw binary output from LWASM along with the CAS file I made. There's also a DECB file made from the same source that demonstrates what `Test' does (clears screen to yellow).
Can you make a working CAS from my raw file?
CAS_Test.rar
(397 Bytes) Downloaded 796 times
Re: File Formats
Bosco wrote:Can you make a working CAS from my raw file?
What are the START and EXEC addresses of your Dragon program?
Re: File Formats
Yes, sorry about that.
0x4000 for both.
Re: File Formats
Done it...
drbincas testraw.bin testraw 16384 16384
DrBinCas v0.4b | Program for converting binary files to .CAS files by Robcfg
cas2wav testraw.cas testraw.wav
raw2cas_test1.zip
(650 Bytes) Downloaded 815 times
Re: File Formats
Hi Bosco,
Please try makewav from the Toolshed utilities http://toolshed.sourceforge.net/ There are binaries under "Files". makewav can produce WAV or CAS from DECB or raw binaries. It is very handy in combination with DECB since the start and exec addresses are automatically detected.
The Toolshed utilities are written in C and run on all platforms. They are actively maintained, and also used for building NitrOS-9.
Re: File Formats
Hi zephyr.
I'm getting mixed results converting LWASM raw binaries to CAS. The little test program I attached does seem ok but other larger programs can look garbled, albeit still running.
Equivalent raw binaries from `asm6809' appear to convert perfectly though, so hat's off to Ciaran. :)
Hi tormod.
I haven't dabbled with Toolshed yet. I'll take a look.
Is the makewav command line to convert DECBs to CAS/WAVs straightforward?
Re: File Formats
Relatively straightforward. makewav by itself will list all options.
makewav -r -c -nFILENAME -ofilename.wav filename.bin
makewav -r -c -nFILENAME -k -ofilename.cas filename.bin
Re: File Formats
Had a go at using makewav with a DECB output from LWASM. Similar issue to before.
Converted my small test program to CAS and WAV without issues but the second program threw this error; `Error: Wrong DECB block length'.
I should add both DECBs work perfectly in XRoar.
If LWASM is the problem I should probably change assemblers. Shame, I like auto branch length and alphanumeric local symbols.
