Shaper (Shards)
daelectron
Shaper (Shards)
Post by daelectron »
I have managed to create a WAV of this Sound Utility which appears to be missing from the Dragon Archive.
There is quite a thick instruction manual. I will see if I can OCR it later this evening and upload it here.
The WAV is available here:
http://www.acornelectron.co.uk/Shaper.zip
Would be great if someone could convert to CAS (and smaller WAV file).
Shaper Front Cover
Shaper Front Cover
Re: Shaper (Shards)
The CAS and optimized Wave files are attached. When are you going to upload the all-important instruction manual?
Shaper (1984)(Shards Software)[!].zip
(27.81 KiB) Downloaded 308 times
