Flicker
Flicker
Hi.
I've hit a problem with flickering graphics.
To demonstrate I've made this short assembly program that puts the Dragon into PMODE 1, then repeatedly clears the screen and draws six coloured blocks vertically in the centre. Despite waiting for the `Field Sync Interrupt' before redrawing I still get a violent flicker over the upper portion of the screen.
Can anyone with more experience tell me where I'm going wrong?
I've attached the source and Bin files.
Thanks.
; Flicker Test
				org $4000
; Constants
GM04			equ $c0 ; colour graphics mode 4 (PMODE 1)
PIA1_PDRB		equ $ff22 ; peripheral interface adapter 1 data register B
SCREEN			equ $0600 ; base address of screen
SCREEN_END		equ $1200
COL_GREEN		equ $0000
COL_YELLOW		equ $5555
COL_BLUE		equ $aaaa
COL_RED			equ $ffff
; Initialisation
			; setup VDG & SAM
			lda PIA1_PDRB
			anda #$07 ; preserve bits 0-2
			ora #GM04 ; overwrite bits 3-7
			sta PIA1_PDRB
			sta $ffc0 ; clear V0
			sta $ffc2 ; clear V1
			sta $ffc5 ; set V2
			sta $ffc7 ; base page 0
; MAIN LOOP
MAIN_LOOP	lda $ff02
@WAIT_TV	lda $ff03
			anda #128
			beq @WAIT_TV ; wait for frame fly-back
			; clear screen
			ldu #COL_RED
			bsr CLR_SCREEN
			; draw coloured blocks
			ldx #SCREEN
			leax $0f,x
			ldu #COL_YELLOW
			bsr DRW_BLOCK
			ldu #COL_BLUE
			bsr DRW_BLOCK
			ldu #COL_GREEN
			bsr DRW_BLOCK
			ldu #COL_YELLOW
			bsr DRW_BLOCK
			ldu #COL_BLUE
			bsr DRW_BLOCK
			ldu #COL_GREEN
			bsr DRW_BLOCK
			bra MAIN_LOOP
; Copy U into all screen addresses
CLR_SCREEN	ldx #SCREEN
@NXT_WORD	stu ,x++
			cmpx #SCREEN_END
			blo @NXT_WORD
			rts
; Draw a block 2 bytes wide and 16 pixels high
DRW_BLOCK	ldb #$10
@NXT_WORD	stu ,x
			leax $20,x
			decb
			bne @NXT_WORD
			rts
Flicker.rar
Execute Address &H4000
(906 Bytes) Downloaded 719 times
Re: Flicker
welcome to the forum!
I have not seen anywhere in the program a sentence to allow interrupts.
Something like
ORCC #$50
that would need another to cancel them before ending the program
ANDCC #$AF
Hope this would help
Re: Flicker
I have been tying your example and it really shows the flicker in the upper part of the screen.
This means that you are taking too much time in your routine and so, the final part of this execution is done when the screen is being redrawn.
You can verify that just commenting the hardest part of your test, the line: BSR CLR_SCREEN
You will see that the image no longer flickers.
So, you can use some cycles from the moment the interrupt arises, but not more than a certain time limit (in time)
The ORCC #$50 is no needed, because these TV signals occur always.
best regards
Re: Flicker
You need to slow it down with a delay loop. Try the attached example.
flicker_test2.zip
(1.08 KiB) Downloaded 738 times
Re: Flicker
Hi pser1, zephyr.
Thanks for taking a look. I suspected I might be drawing too much but didn't want to rule out other possibilities.
I'm experimenting at the moment, getting a feel for what the Dragon can do. I might try drawing to a `back buffer' and flipping the display page base address when the scanline flys back to the top of the screen.
