Inverse text routine
Listed below is an inverse text routine which you can use in your own BASIC programs. This is a slightly modified version of the routine I used for Jim Gerrie's METEOR game.
Notes:
(1) The routine includes a PRINT CHR$(12) feature for clearing the text screen in inverse (inverse CLS).
(2) Use SCREEN 0,0 or SCREEN 0,1 (orange text) to switch back to text mode after using PMODE graphics.
10 CLEAR 200,32568
20 GOSUB 10000
30 PRINT CHR$(12): REM CLEAR THE SCREEN (CLS)
40 END
10000 ' POKE-IN THE MACHINE CODE
10010 FOR I=32568 TO 32764:READ A$:POKEI,VAL("&H"+A$):NEXT
10020 ' ENABLE INVERSE TEXT
10030 EXEC 32568:RETURN
10040 ' DISABLE INVERSE TEXT
10050 EXEC 32598:RETURN
10060 DATA CE,1,67,30,8D,0,44,AC,41,27,12,A6,C4,A7,8D,0,B4,EC,41,ED,8D,0,AF,86,7E,A7,C4,AF,41,39,30,8D,0,29,BC,1
10062 DATA 68,26,E,A6,8D,0,9A,B7,1,67,EC,8D,0,94,FD,1,68,39,CC,20,27,8E,4,0,9F,88,A7,80,8C,5,FF,23,F9,E7,8D,0,12
10064 DATA 35,F6,D,6F,26,76,32,62,34,76,9E,88,81,20,24,2D,81,D,26,C,86,20,A7,80,1F,10,C4,1F,26,F6,20,2E,81,8,26,D
10066 DATA 8C,84,0,27,51,86,20,A7,84,A7,82,20,1D,81,C,27,B8,81,D,26,41,C6,26,20,BF,4D,2B,C,81,40,25,8,81,60,25,2
10068 DATA 84,9F,88,40,A7,80,9F,88,8C,5,FF,23,25,8E,4,0,EE,88,20,10,AE,88,22,EC,88,24,EF,81,10,AF,81,ED,81,8C,5
10070 DATA E0,25,EA,9F,88,CE,20,20,C6,10,EF,81,5A,26,FB,35,F6
I have also attached a copy of the BASIC example program in .CAS and .WAV format. I recommend using Audacity 1.2.6 to convert the included wave (.WAV) file to a real audio cassette recording.
INVTEXT.zip
(2.07 KiB) Downloaded 462 times
