Draconian by Microdeal
daelectron
Post by daelectron »
The .CAS version of this file in the archive here doesn't seem to work, although the .WAV file works perfectly. Could someone upload a working .CAS version please?
Here are the instructions:
Draconian
This has to be one of the most exciting programs for the computer ever released. The most outstanding graphics and sound you'll ever see or hear. The player controls a spaceship capable of moving in eight different directions. The joystick controls the direction of the ship. Pressing and holding down the fire button will deliver a rapid-fire stream of shots. Player 1 controls his ship with the right joystick; player 2 uses the left.
Game Objective
The object of the game is to destroy all of the Enemy Bases within each sector, rescue as many Astronauts as possible, and dock with the Friendly Base at the top of the sector.
Sector Scanner
The Sector Scanner is the large black box on the right of the screen, immediately below the player's score. The locations within a sector of each of the Enemy Bases are shown on the scanner by a white dot. The location of your ship is shown by a small red dot. In addition, the entry and exit locations for the sector are shown as white dots at the top and the bottom of the Sector Scanner. The Sector Scanner is provided to allow you to determine your position relative to the Enemy Base.
Enemy Bases
The Enemy Bases consist of several gun turrets connected by beams. To destroy an Enemy Base, shoot each of the gun turrets. When all of the turrets have been destroyed, the base will disappear, freeing the Astronaut or Astronauts inside. Beware: in later sections the gun turrets will fire on you!
Astronauts
Each Enemy Base has one or more Astronauts held captive within. When an Enemy Base is destroyed, the Astronauts can be picked up. This can be accomplished simply by flying over him.
Astroids & Space-Mines
Throughout each sector, there are numerous Asteroids and Space-Mines scattered in your path. Running into these will destroy your ship. Shooting the Asteroids and Space-Mines will destroy them, but *be careful*! Flying through an explosion is just as fatal as running into something!
Dragons
Then Dragons fly around the sector, trying to run you down and destroy you. You may shoot the Dragons to kill them.
Sector Edges
The edges of the sector are represented by a solid wall. Flying into a sector edge will result in your hip "bouncing" off of the wall. Bouncing off an edge will also cause you to temporarily lose control of your ship's direction of motion, although this is *quite* temporary.
Draconian
If you take too long to destroy all of the Enemy Bases, a warning will begin to flash on the right of the screen. This indicates that the Draconian is about to appear. The Draconian is indicated on the Sector Scanner by a blue dot. It is not possible to kill the Draconian by shooting it!
Docking
Upon destroying all of the Enemy Bases, a flashing arrow will appear at the top of the Sector Scanner. This indicates that the exit gate is now open. Upon flying through the gate (which is located where the arrow is pointing), your ship will revert to computer control (in other words, sit back, relax, and enjoy the scenery. You earned it!) A bonus will be awarded based on the number of Astronauts you collected within the sector. Note: If your ship is destroyed, all of the Astronauts you were carrying are also destroyed.
Extra Ships
The number of ships remaining is indicated by the ships shown in the bottom right corner of the screen. An extra ship is awarded at 10,000 points, at 60,000 points, and at each additional 50,000 ppoints.
Starting A Game
The program begins with an introductory sequence. This sequence may be interrupted by pressing the SPACE BAR during the music. The computer will then ask 'Number of players?' Press either 1 or 2, and the game will start.
Scoring
Destroying an Asteroid = 20pts
Destroying a Space-Mine = 40pts
Destroying a Dragon = 100pts
Rescuing an Asteroid = 500pts
Game Controls
Joystick controls apply.
ENTER/SPACE - Pause/Resume
BREAK - Abort Game
Loading
CLOADM (ENTER)
Draconian Front Cover
Re: Draconian by Microdeal
A copy of this title (.cas format) has already been uploaded by robcfg on April 15th, 2012. It was dumped from the original cassette, and tested on XRoar and a real Dragon. He was also kind enough to take the time to create a nice wiki page with good quality pictures of the original inlay card, full instructions, and screen shots.
Please check the archive and forums carefully before posting requests for software.
daelectron
Um yes, well that may be the case - but I didn't download the version from the Wiki page, I downloaded it from the software section. I just downloaded it again from the software section and there it remains broken. I downloaded the version from the Wiki page that you mentioned and this one works correctly.
Perhaps update the version in the software section in case anyone else downloads it from there?
daelectron
And also the Wiki entry doesn't have the instructions in txt format, only as an image.
rolfmichelsen
Post by rolfmichelsen »
The downloads section contains two copies of Draconian, one is the Version from the Wiki and then there is an older Version. Presumably, it's the older Version that is broken. Maybe it should be removed.
Yep, maybe we need some cleaning.
On my side, when I create or update a wiki page I link to the best version available, and I don't delete other versions, just in case they are slightly different.
rolfmichelsen
robcfg wrote:On my side, when I create or update a wiki page I link to the best version available, and I don't delete other versions, just in case they are slightly different.
Yep, that has been my approach as well. Storage is cheap compared to a mistakenly deleted thingy that fulfils some purpose I'm not aware of.
