Here is a program I wrote for easy merging of BASIC programs. The program is compatible with all CoCo and Dragon machines. It will also work on a Dragon 64 in 64K BASIC mode. The instructions for use are as follows:
1. LOAD the APPEND machine code program
2. LOAD the first BASIC program
3. Enter EXEC
4. Load the next BASIC program (Renumber if necessary)
5. Enter EXEC
6. Go back to step 3 if more programs are to be appended
EDIT: Attachment removed.
APPEND (Program for merging BASIC programs)
Re: APPEND (Program for merging BASIC programs)
Fixed a bug which caused the prevous version to fail on BASIC programs with a line zero.
- APPENDv1-1.zip
- (872 Bytes) Downloaded 284 times
