Breakout/Middle Kingdom by Dragondata
daelectron
Post by daelectron »
Breakout
Breakout is a machine code version of the arcade classic. Your task is to keep the ball in play for as long as possible while knocking bricks out of a wall as it descends towards you.
Playing The Game
On starting a new game, the ball will move towards the top of the screen as the bricks start moving down. If you miss a ball, another will be placed upon the screen providing you have some left. The number of balls remaining is shown at the bottom left of the screen.
When the game is over, press the Space Bar to restart.
Game Controls
Arrow Left/Arrow Right - Move left and right
1-5 - Select Skill level
J/K - Select Joystick/Keyboard mode
SPACE - Start game
If using a joystick, it should be plugged into the right hand joystick port.
Loading
CLOADM "BREAKOUT" (ENTER)
EXEC (ENTER)
Middle Kingdom
The object of this real time graphic adventure is to become the ruler of Middle Kingdom. This is achieved by returning the three Magic Rings to the sanctuary. The Magic Rings have been randomly scattered throughout the Kingdom and to recover them you must search the rooms of the Catacombs, Temple and Pyramid, but be warned there are main different monsters lurking in the rooms.
Playing The Game
Firstly, you must decide the skill level, this determines the number and complexity of rooms and hence the difficulty of the adventure. Skill level 1 is the easiest.
You then must choose your character - a magician, a merchant or a warrior. Spells are more powerful than weapons.
The last question asks for the speed at which messages are displayed on the screen. If you are playing this adventure for the first time, it is recommended that you select the slow speed.
You will initially appear in the sanctuary. To move your character use the appropriate arrowed keys on the Dragon keyboard.
To aid you in your quest there are elixirs, weapons and spells randomly distributed throughout the Kingdom. The elixirs will increase your strength, while the weapons and spells are used in combat.
As you move around the Kingdom you will find the various objects. To pick up any of the treasures, weapons or spells simply walk into it. However in some of the rooms a monster will appear and you must defeat it before you can leave and continue your exciting adventure. The longer you remain in a room, the greater the chance of being attacked.
During combat a flashing cursor will appear on the selected weapon. To change the weapon simply type the number which appears above the weapons during combat. When it is your turn the weapon selected at that time will be used. Some weapons have a higher chance of hitting the monster, but do less damage. If you use the same weapon too frequently the weapon's performance will drop and may eventually break. The fireball and lightning spells are very powerful and will do a lot of damage, but should only be used infrequently. The stun and petrify spells will finish the combat if they work, but should also be used infrequently. If no weapon is currently selected, the message "you hesitate unsure" will appear. To defeat the monster you must reduce its strength to zero.
The game ends if your strength reaches zero or when you have returned the three Magic Rings to the Sanctuary.
Loading
CLOADM "KINGDOM" (ENTER)
EXEC (ENTER)
Files: http://www.acornelectron.co.uk/Breakout ... ingdom.zip
daelectron
Re: Breakout/Middle Kingdom by Dragondata
The .CAS file of Middle Kingdom already exists in the archive but the Breakout one does not work. So if someone could convert the WAV file to .CAS format that would be great.
Here are the .CAS files for these games.
BREAKOUT_AND_MIDDLE_KINGDOM-CAS.zip
(10.09 KiB) Downloaded 319 times
