Number Gulper
Introduction
Number Gulper is a program which encourages children to practice number skills - addition, subtraction, multiplication and division - in an interactive game.
The player is asked to build numbers using only those displayed on the screen. As there are nineteen different levels in the game, children of all abilities can enjoy using it. At the highest levels, to add to the challenge, interfering scramblers appear which have to be avoided.
The game can be played using either a joystick or the keyboard controls.
There is also a self-test option which enables children to check their progress in a more formal way, testing themselves against the clock.
How To Use It
First, choose whether you want to play the Gulper Game or Gulper Self Test. Press 1 or 2 and then the ENTER key.
Gulper Game
Decide whether you want to play using a joystick or the keyboard controls, press 1 or 2 and then ENTER. (Remember the joystick must be plugged into the right hand port of your computer.)
Next you will be asked to type in the first number you want to make. This must be between 10 and 9999. If you have not played before, it is best to start with a small number, e.g. 20. Type in the number, and press ENTER.
A "board" now appears on the screen, in the top two green boxes, there are two important numbers, the MAKE number (which is the number just selected by the player) and the MADE number. The MADE number is selected by the computer and depends on the level chosen. The aim is to "gulp" numbers on the track to change the MADE number until it is the same as the MAKE number.
In the blue box in the centre, there are three red gulpers, and on the yellow track there are numbers each with a sign (+, -, x or /) next to them.
To start, press the space bar. The first gulper will move onto the yellow track. Move the gulper around the screen using the four arrowed keys or the joystick. To change the MADE number, "gulp" a number by pressing the spacebar or the serve/fire button on the joystick when the gulper is over that number. If neither of these is done then the gulper will just pass over the number without gulping.
For example, imagine you are starting with a MADE number of 5, and have to equal a MAKE number of 20. Look around the track and see what numbers are available for gulping. If there are 5+, 8+ and 2+ on the track, you can gulp each in turn to give a total MADE number of 20, and your gulper will get into the HOME base. Often, it will not be as easy as this, for example it may be necessary to gulp 5+, 1+ and 3- in order to add 3 to the MADE number.
Don't forget about the red energy/time bar on the display. As a gulper moves around the track, and each time it gulps a number, it uses energy. You must change your MADE number to equal the MAKE number *before* the red energy/time bar disappears. (To do this, it often helps to plan your moves *before* you press the space bar to start your gulper off.)
If you succeed in changing the MADE number into the MAKE number, the gulper goes into the HOME base. If not, due to using too many gulps, or delaying too long in making the number, it disappears. In both cases, new MADE and MAKE numbers appear and when you are ready, press the Spacebar to start with the next gulper.
If you get 2 or 3 of your gulpers home then you will be given a harder level for the next game. If you get no gulpers to the home base then you will be given an easier level to try. Your current level is shown in the green box at the bottom of the display.
From level 8 onwards, scramblers appear on the track, which must be avoided. If a gulper hits one, that gulper returns to the base (the blue box) but, more importantly, the MADE number is randomly altered. You now have to rethink how to construct the MAKE number from the new MADE number. When you are ready, press the space bar to put the same gulper back onto the track.
Note that when you gulp a division number e.g. '5/' it must divide *exactly* into the MADE number. If it doesn't, a "WON'T DIVIDE" message appears in the bottom green box. To continue press the space bar.
It is not possible ot have a MADE number bigger than 9999. If you try to do this, a 'MADE TOO BIG' message appears. Equally, you cannot have a MADE number smaller than zero. If you try to do this, a 'LESS THAN 0' message appears. In either case, press the space bar to continue.
Gulper Self Test
If you decide on the self test option, the first thing you have to do is to type in the level reached in the last gulper game, and press the ENTER key. Now you are asked how long you think it will take you to do the test. Bear in mind while deciding that you will have ten problems to do. After typing in the time in seconds, press the ENTER key to start. A problem will come up on the screen with the numbers having the same form as they had in the gulper game.
Work out the answer, and type it in, followed by ENTER. If the answer was correct, another problem will be displayed. If the answer was wrong, the answer will be rubbed out, and you get a second go. If this is also incorrect the correct answer will be shown and a new problem is displayed. After ten problems have been completed, the actual time taken is now displayed, and the correct answers you gave will flash in order. The space bar now appears, press it when you are ready to continue. The game now returns to the beginning of the self-test option.
In All Young Learning Programs
ENTER - Remember: Once you have typed in your response, a program will not deal with it until you press ENTER
SHIFT-Arrow Left - You can always return to the beginning of the program just by holding down SHIFT and pressing the arrow left key
Hand Icon - Means: Please press the space bar to carry on with the program
? - Means: The program did not expect the response it has just received. Perhaps there was a typing error? In any case, to carry on, just press the space bar and try again.
Many of our programs incorporate sound. Make sure the volume control on your TV is turned up sufficiently if you wish to hear it.
Loading
CLOADM (ENTER)
The programs will begin automatically after loading.
Number Gulper by Dragon Data
daelectron
daelectron
Re: Number Gulper by Dragon Data
OK, now I'm not exactly sure whether there *is* anything wrong with the .CAS version on The Dragon Archive on this one. I haven't checked it again but I have written in my notes on all the CAS files I have that this one "has issues". Probably this means it crashed when I originally played it on Xroar last year.
Anyway, if the CAS version *is* broken, hopefully someone can convert this WAV file to CAS and replace the broken with a working version. And if it *isn't* broken well I suppose it never hurts to have a .WAV version as well, just in case.
Here is the .CAS file for this game.
- NUMBER_GULPER-CAS.zip
- (12.3 KiB) Downloaded 378 times
