Hide & Seek by Dragon Data
daelectron
Post by daelectron »
Another game I have managed to track down. The archive version (here at Dragon Archive) only has one side of the cassette (the A side).
Actually the tape is different on each side - there are four games in total. Side A has two. Side B has two more.
Instructions are:
Hide And Seek
Introduction
The games in Hide And Seek are all variations on Pelmanism and the age-old "Kim's Game". They are designed to encourage and develop short term memory and other skills important for learning to read.
In Hide It, and Seek It, objects are put into boxes, which then close, and you have to remember where the different objects are hidden. There are various levels of difficulty and lots of different objects, making it enjoyable for children of all ages.
In What's Missing, the objects are again put into boxes, but this time the boxes open and obe object is found to be missing. You have to identify which object. (Here, players can adopt different strategies, such as classifying the pictures in sets, to remember the locations and assist their memories.) You are then asked to read or type in the name of the object that you think is missing, and can use the Dictionary section below to help you.
Pairs or small groups can play, taking turns at guessing and using the keyboard. A reader can help a non-reader to use the dictionary. Parents will often find that their children are better at the games than they are.
How To Use It
Side 1
You will be shown a menu for the two games on this side. They are Find It and Seek It. Find It is a little easier than Seek It because it only has six boxes, but the rules for playing are very similar.
Type A or B for the ame you would like to play, followed by ENTER.
Find It
Pictures appear in the box at the bottom left hand side of the screen and are transferred one by one to the block of six boxes. Watch carefully, you have to remember which picture goes in which box.
When all the boxes are full, shutters come down. One of the pictures then re-appears at the bottom and you have to decide in which of the six boxes it is to be found. Having decided, you can look in that box to see if you're right. Press the Space Bar to position the cursor into your chosen box and then press the ENTER key to open the box.
If you're right the box will stay open and you'll get another object to find, if not, you get another turn at locating the same picture but if you get it wrong again the correct box is opened for you.
When all the boxes are open, those whose contents you remembered correctly are flashed. Count them to see how well you did. After that press the SPACE BAR for another game.
Seek It
In Seek It, you must now choose one of four different games to play. The first of these is hard, the others are worse! In every case you have to remember which picture went into which box, and there are now nine boxes.
Type A, B, C or D for the game you would like to play, followed by the ENTER key.
Games A and B
The pictures appear one by one at the bottom of the screen and have to be put into boxes. Decide which box a particular picture should go into by using the SPACE BAR to move the cursor to the appropriate box. Pressing ENTER then causes the picture to be transferred.
Once all the boxes are full, the shutters come down. One by one the pictures re-appear at the bottom of the screen as before and you have to decide on the whereabouts of each picture. The SPACE BAR is used to select the box you think the picture is in and the ENTER key opens the box. As before, you get two tries, after which you are shown where the picture is, but it is then hidden again. Press the SPACE BAR to continue with the next picture.
At the end, all the shutters are opened and you are shown which pictures you found. When you press the SPACE BAR you will be shown a Score Card, with the time taken and the number of points you scored. How many points can you make? One hundred is the maximum!
Game C
In this case the pictures are put into the boxes for you. When the boxes are full, press the SPACE BAR to continue, and the game is then just the same as Games A and B.
Game D
Here the pictures are again put into the boxes for you, but the shutters now come down immediately after each box is filled. When the boxes are full, press the SPACE BAR to continue.
The cursor now flashes from box to box and eventually comes to rest on one of them. You now have to remember what is in that particular box.
Pressing the SPACE BAR in this case causes the pictures to appear one by one at the bottom of the screen. When you come to the picture that you think is in the box with the cursor in it, press ENTER.
If you are right, the box will flash, your success will be remembered but the box will close again and you should press the SPACE BAR to continue.
If you're wrong, the box will close and you should press the SPACE BAR to continue.
The cursor will return to that particular box later.
The game ends when all nine pictures have been successfully located and once again you will be shown a Score Card.
Side B
Again you have a choice of games to play. Read It or Spell the Name. The main difference between the two is that with Read It, you only have to use the SPACE BAR and ENTER keys, whereas with Spell the Name, you have to type in the names of the objects. So, would you like to read, or spell?
Type A or B for the game you wish to play, followed by the ENTER key.
Read It
An object appears in the first box, and its name appears at the bottom of the screen. Read the name and remember which box that object is in, then when you are ready, press the SPACE BAR to continue. The next object, with its name, now appears and this continues until all the boxes are filled.
The shutters on the boxes are then lowered and raised, to show that one of the objects is missing.
You are now asked "What's missing?", and an object is suggested, for example "Is it the Church?"
Press the SPACE BAR to see all the alternative suggestions as to what is missing and when you think you have found the right one, press the ENTER key.
If you are right, the missing object will appear in the empty box and flash. If you are wrong, you can have two more tries, after which you will be shown the missing object.
Press the SPACE BAR to play again.
Spell The Name
You are first asked to put the objects into boxes. Use the SPACE BAR to choose a box, then press ENTER to put the object into it.
Remember where the objects are and when all the boxes are filled, press the SPACE BAR to continue.
The shutters are now lowered and then raised to show that one of the objects is missing. This time you have to complete the sentence - It's the ...... - by typing in the name of the missing object.
If you are right, the missing object will appear in the empty box and flash, if you spell the name incorrectly, or type in a word not shown in the dictionary below, the ? symbol appears. Press the SPACE BAR and try again. After three tries, you will be shown the missing object.
Dictionary
baby, bicycle, boy, bus
car, caravan, castle, cat, church, circle, clown
diamond
elephant
fir tree, fish
geranium, girl
heart, house, hut
lorry
man
oak tree, owl
parrot, pig, pram
rectangle, rose
school, square
triangle, tulip
violet
windmill, woman
In All Young Learning Programs
ENTER - Remember: Once you have typed in your response, a program will not deal with it until you press ENTER
SHIFT-Arrow Left - You can always return to the begging of the program just by holding down SHIFT and pressing the arrow left key
Hand Icon - Means: Please press the space bar to carry on with the program
? - Means: The program did not expect the response it has just received. Perhaps there was a typing error? In any case, to carry on, just press the space bar and try again.
Many of our programs incorporate sound. Make sure the volume control on your TV is turned up sufficiently if you wish to hear it.
Loading
CLOADM (ENTER)
The programs will begin automatically after loading.
daelectron
Re: Hide & Seek by Dragon Data
OK, these files are uploading now to:
http://www.acornelectron.co.uk/Hide_And_Seek.zip
I have put the wavs of Side A and Side B in this zip. Obviously Side A is already available as a .CAS file. If someone could made Side B into a .CAS as well that'll be one more Dragon tape archived, hopefully forever.
I've got a few more to come too. Hopefully they'll all transfer this well and this quickly.
daelectron
Needless to say, wait five minutes before attempting to download please.
Its exactly the same game on both sides of the tape.
daelectron
Again, sorry about that. I had to do a number of transfers of the game until I got one to work and somehow it looks like a dodgy side A got renamed as the working Side B. It's really useful to upload them in this way though because it means that the disasters go get caught - before I've sold the original tape and it turns out it hasn't actually been archived!
The version on the above link now 100% definitely contains a working Side A and a working Side B of this game. And very good it is too... for young children.
Here are the .CAS files for this game.
HIDE_AND_SEEK-CAS.zip
(24.03 KiB) Downloaded 204 times
