Connecting a Dragon to a vga monitor.
Gareth_O'Flaherty
Post by Gareth_O'Flaherty »
Is it possible to connect a Dragon 32 to a pc monitor with a vga port? What lead or adapter would I need?
Thanks.
Gareth
Got my first Dragon 32 in 1983 (where does the time go??).
Re: Connecting a Dragon to a vga monitor.
You could try a VGA box and connect it to the Dragon via the monitor port, for what you need the composite to din lead.
Gareth_O'Flaherty
Thanks for the suggestion robcfg!
Then there's the question of what do you do for sound...
